Originally Posted By: mechtech2
mechjames - Can you leave that break in oil longer? Are you sure it has to be dumped so soon?
It might be good and smart to run the engine with that break in oil in there for a longer time, for a bunch of reasons.
This time we added 5 qts Rotella T 15w40 and a Quart of Comp Cams Break-in 10w30. The old oil came out grey, only after running for half an hour. They just loaded that 3/4 race cam with moly disulphide.
Originally Posted By: Pop_Rivit
Every flathead that I've rebuilt (both Ford tractors and Dodge Power Wagons) I've used Rotella in them. It's a very good choice for most flathead engines.
We bought the 9L jug tonight, and he's going to buy a pail since it's so cheap.
Originally Posted By: fraso
Chrysler's oil recommendations[/url] remained virtually unchanged from the 1930s up to the 1960s. I would expect that the 1950 Dodge engine is very similar to the 1936-1942 Plymouth engines, which the factory recommended a 20 or 30-weight oil for summer-time driving.
Considering fact that the viscosity index of oils of that era were fairly low, any modern 10W-30 HDEO would have sufficient viscosity even for a modified flat-head engine. If you want the best oil for this engine, seeing as you're also in Canada, you should consider
0W-30 Esso XD-3 Extra.
My local parts store stocks 10w30 Rotella, which is apparently hard for most BITOGERs to find. Being in Canada means nothing. It was 15 degrees today (59 degrees). As you can see, our olympics got barely any snow. It stayed warm at sea level, where I am.
Heck, I ran 10w40 pennzoil in my explorer v6 last year, it ran fine. A 40 wt in an older flathead with tolerances that aren't as tight as a modern engine will work great.
