Getting ready to change out the diff lube on my 05 Titan. (I have posted earlier about recommended lubes). It needs synthetic 75-140. I was checking out my local wally mart and noticed the ST 75-140 "full Synthetic" near the boat section. It was 10 bucks a quart. Should I risk it? Has anyone else used it in their diffs? I know ST motor oils are okay. If it is iffy, then I will use M-1 or Redline. My truck does not see much towing, but the rear diff is a little delicate for the torque that the VK56DE puts out (I am pretty much stock). This diff has the towing gears (3.357).
Thanks,
Dave
Thanks,
Dave
