Originally Posted By: JimPghPA
11.5 Volts only indicates that the battery probably would still be usable if you charged it. At 11.5 Volts it might be close to completely discharged. I would put a charge on it after 3 years just to reduce the probability of it being stored with a very low amount of charge on it.
X2. A battery is considered discharged when it reads 11something volts and not when it reads 0 volts as you would think. Letting it sit uncharged will cause sulfation. I doubt if it will recharge since it's been sitting discharged so long.
