I ran Superflo way back in the day in the GN. I say back in the day because I'm still running it off of the 5 year old stash. Mine is a hydraulic flat tappet with 100lb springs and a rev limit of 6,200 with normal "racing" shift points of 4,500rpm. In other words, my requirements are likely less than the OP's requirements. Still, 1,400ppm should be more than enough for even an aggressive solid cam with heavy springs.
I highly suggest Redline. Amsoil's ACD is also a great oil that meets the requirements and is priced very competitively.
