Originally Posted By: saaber1
Originally Posted By: Oregoonian
I mean, lets face it....will that vehicle last any longer if you put $60 of oil in it or $30 each time you change the oil???
In my personal experience, yes it does last longer. I have had saab turbos that lived their entire life on redline and were mechanically within factory specs at 318k miles. I would say that many high end synthetics such as amsoil etc. are well worth the cost.
Here is an anectdote from Barkerman as another example:
"Red Line is a good daily driver oil and it just might make your engine last longer. We have several 300k+ cars around here that use nothing but Red Line and it's not that they are over 300k but that they are over 300k with no internal mechanical work and to a boroscope look like new inside. I know a few examples don't prove a point but they are a good indicator. One fellow delivers some kind of radio-active isotopes with his 78 Toyota pickup and has 510k miles on Red Line with nothing more than regular maintenance and about 4 water pumps. He also uses Frantz oil and fuel filters and a spin-on coolant filter with an anode. He is on the original camshaft and valves. I've done a compression check and it's withing 5% of new specs and the spread from high to low is 8psi. You can still see the hone marks at the bottom of the cylinders and there is only a cosmetic ridge at the top of the cylinders. Granted this series of Toyota 4 bangers is considered to be a good engine I think that Red Line is performing well. He started with Castrol 10w-30 with the new truck and a few years later after hanging around our shop switched to Red Line 10-30 and has graduated up to 20w-50 a couple of years ago. His oil consumption is 1 quart in 5k miles. Granted he is a careful driver because of his cargo and LA has no weather but I think he is doing well. He recently dropped a bundle in rebuilding the suspension front and back, complete brake job and replaced all the flexible brake lines, master cylinder, rear wheel cylinders and new calipers, including his second tranny rebuild for bearings and seals, no other hard parts also using Red Line MTL. He also had the seals replaced in the rear end and uses Red Line gear lube and uses that red colored Red Line CV2 grease in the grease fittings (yes it has fittings you grease with a hand gun). All this was his answer to the question of buying a new pickup or keeping the old one. I think it can be said that he likes the old one. The company he works for footed the bill for a complete repaint and upholstery job. We talked Yokohama into making him a screaming deal on some new Avid TRZ's. His only problem is that we can expect a letter from Congress about his disregard for the economy by not just junking his pickup and buying a new one. He is hoping that the new sound system including a CD player for his books on CD will be useful in his defense. But to those that think Red Line is only good for racing we think it performs well for commuting but is an expensive choice. Sorry for running on I just though this is an unusual case and you might be interested."
I'm sure there are many out there that have over 300K on their vehicles...and used only dino with regular oil changes and Fram filters.
The key word is 'proof', not personal experience, because many use various oil products and their 'personal experience' shows that their oil is as good as the rest.
In the Barkerman quote the key word is 'might' last longer...not 'will' last longer.
I glad you think that this oil is so superior..because I've heard that Saab's are garage queens...so anything that can improve that reputation has to be useful. In the meantime, I'll enjoy saving $$$ and having fun useing it in more benificial ways.
