Most modern compressors cycle.
Too rapid or never cycling shows a problem - wrong refrigerant amount or a bad switch, maybe even a a puked compressor.
When you check the low side pressure, do it only when the compressor clutch is engaged, not in the rest cycle. The rest cycle reads much higher pressure, and you won't really be filled enough.
