99 Dodge Dakota, 4wd 5.2 engine. 118,000 miles
Was notified upon getting an alignment for new tires to be installed, that my inner tie rods have excessive play and need to be replaced.
How bad of a job is this to do. Looking at the book and under the truck, this seems like a fairly simple job. Disconnect them, unscrew the piece from the drag link, do some measurements, take it all apart, put together back as close as possible, screw back on, re-assemble to control arm, do other side.
Is there anything else looming about the job that I'm missing?
Should I fork out for the Moog or Raybestos versions instead of the what ever brand at Auto Zone?
Thanks!
Thanks!
