Hi folks - hope everyone's enjoying as nice a day as I am. Finally some sun in drenched North GA.
Ok so I bought this 8 GAL, 2HP air compressor from Harbor Freight a couple years ago. Filled it with uhh... Ingersol I believe... standard compressor oil as recommended. Ever since I've had it, it has sometimes thrown the relay when starting up until it finally warms a bit (?) then it'll keep running.
I don't even know how often the oil should be changed, but I'm sure after two years of even light use it probably needs changing due to moisture.
Anyway, should I use the standard stuff or could I use something like PP 0w30 that I use in my mower?
The compressor runs good and seems to not throw the relay near as much as it used to - maybe it just needed 'breaking in'. I just want thoughts on the best oil for it, whether it be the standard stuff or something more 'weird'.
