Greetings:
Does anyone out there know where the headlight relay is on a 2002 Buick Century? My parents car is having intermittent headlight failure and from what I gather from the 'net it is usually the relay ($$) or the turn signal/dimmer/cruise switch unit ($$$.) The dash switch isn't what normally fails as they are rarely used on the cars with automatic headlights - it is only used when you want to turn them on manually.
My dad is trying a new relay first (was only $16) but can't find it. I think it is under the hood but the fuse box there is labelled and none of the relays are marked as "headlights."
It is tough as I am not where the car is and all of the information that I have from him has been over the phone. Thanks for any help on this!
Andrew S.
Andrew S.
