So the Tahoe had a very small oil leak. I noticed this in late Dec. when I was doing an oil change. Oil filter was wet on the bottom, bottom of oil pan was wet, starter had oil on it, ect. Took it in and they said it was a rear main seal leak and rear cover leak. $553 to fix. I was hesitant to have the work done because I pulled the cover on the transmission and the flywheel was dry, meaning the rear main wasn't leaking. I was assured it was the rear main seal and rear cover so I had them do it.
I've driven ~2,000 miles since the rear main seal was replaced and rear cover was resealed. I looked under there today and guess what? Oil on the bottom of the filter, oil pan, etc. just like before.
They have a 12 month, 12,000 mile warranty. Guess the car is going back to the shop over spring break. Should they do addition repairs at a reduced price or possibly free since it wasn't the rear main seal and I paid them $553?
What could it be? Any ideas?
I can't go to the shop until I'm home from college over spring break. I'm thinking about buying dye and putting it in the oil before I drive 3 hours home and then having the shop look at it with a UV light. I was planning on calling them a week before I head home and explain the situation and see what they say.
