Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
117 registered members (Anduril, apollo18, 928, 2012AccentSE, aquariuscsm, ABomb369, 8 invisible), 2,274 guests, and 21 spiders.
Topics301,698
Posts5,200,852
Members70,759
Oh BTW if you have a 2GR-FE engine....... #1775126 02/09/10 10:56 AM
P
PT1 Offline OP
P
Might want to check this out. The 2009 and up models have designed this out but 2008 and before beware....( my Lexus ES350 was recently done for free by the dealer on my last visit)
http://au.toyotaownersclub.com/forums/index.php?showtopic=22775
While we are bashing Toyota I figure I would throw this on the pile as it is a real issue and there is a fix program out there that many don't know about. The video is a must see. Sure opened my eyes.. shocked
FWIW, the replacement parts ar $32 if you wish to DIY
Re: Oh BTW if you have a 2GR-FE engine....... [Re: PT1] #1775131 02/09/10 10:58 AM
B
bepperb Online Confused
Online Confused
B
This happened to a RAV4 in another forum I participate in...
2016 Honda Pilot
2011 Toyota Sienna 3.5
Recently Gone:
2004 Highlander 2.4
Re: Oh BTW if you have a 2GR-FE engine....... [Re: bepperb] #1775132 02/09/10 10:59 AM
P
PT1 Offline OP
P
Yeah any 2GR-FE and some of the Ravs have the v6
Re: Oh BTW if you have a 2GR-FE engine....... [Re: PT1] #1775415 02/09/10 02:09 PM
B
Billy_D Offline
B
I am glad I don't have the 2GR-FE.
Re: Oh BTW if you have a 2GR-FE engine....... [Re: PT1] #1775435 02/09/10 02:26 PM
Samilcar Offline
The changeover to the all metal oil line took place in May 2008, so later production 2008's have the all metal line from the factory, but earlier 2008's don't.
Re: Oh BTW if you have a 2GR-FE engine....... [Re: Samilcar] #1793677 02/24/10 11:42 AM
P
Paul3637 Offline
P
Toyota is issuing a world-wide recall on the defective oil line. This is a critical issue for all 3.5L Engines made prior to mid-April 2008.
Here is an update as of yesterday
TOYOTA V6 OIL LINE SCANDAL
http://sites.google.com/site/toyotav6oillinescandal/
(BTW: 09 Camry V6 here with 15K using Pennzoil 5W30 and using zero oil betwween 4K changes. 30 mpg everyday driving 50/50 city highway driving. Crankcase capacity is 6.0 quarts not 6.4 per owners manual. Dipstick is defective and can only be read accurately when car sits (eight hours or overnight).
Re: Oh BTW if you have a 2GR-FE engine....... [Re: Paul3637] #1793691 02/24/10 11:53 AM
Z
Zedhed Offline
Z
"And the hits just keep on comin'......."
Re: Oh BTW if you have a 2GR-FE engine....... [Re: Zedhed] #1793718 02/24/10 12:11 PM
ls1mike Offline
Eh, I don't like Toyota, there I said it, but that is an easy fix and it has been recalled which is good for the folks who can't or won't fix it themselves.
It just looks like the original one was designed to have an expansion joint, hence the rubber piece, so it would weap, leak what ever you want to call because, well heated rubber and oil in the engine compartment. Apparently they went back and looked at it and deciede an all metal one would work fine.
Engineers at work again.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Oh BTW if you have a 2GR-FE engine....... [Re: ls1mike] #1801908 03/03/10 09:48 AM
U
USA1 Offline
U
I don't like Toyotas either. The mania about them is unjustified. I would suggest that this metal/rubber pipe be replaced with a 100% metal pipe by the DEALER ONLY. After looking at the link PT1 showed, it is an EXTREMELY INVOLVED REPLACEMENT PROCEDURE, and working in EXTREMELY tight quaters. It's Toyota's fault the rubber pipe was used between two metal pipes. Let THEM skin their knuckles and get frustrated... Worldwide recall indeed!
Re: Oh BTW if you have a 2GR-FE engine....... [Re: Paul3637] #1801923 03/03/10 10:02 AM
RTexasF Offline
Toyota says it is not a recall but a limited service campaign.
Re: Oh BTW if you have a 2GR-FE engine....... [Re: RTexasF] #1802087 03/03/10 12:06 PM
E
EricF Offline
E
service campaign.. by them stating this, they can say it's NOT a recall, although it is.
I'll bet they're trying to find a way to misdirect all their woes..
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
Re: Oh BTW if you have a 2GR-FE engine....... [Re: EricF] #1802162 03/03/10 01:12 PM
Schmoe Offline
Easy fix????? You kidding???? That's a LOT of work.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
