No, Cadillac does not recommend Heli-coils. In fact, they recommend AGAINST Heli-coils. Heli-coil is a brand, and their inserts are not long enough. The GM-backed repair is from Timesert:
http://www.timesert.com
And, if the 2AZ-FE engine uses the M11x1.5 bolts, then Timesert has a kit to replace those. Nobody should jump to the conclusion that the engine needs to be replaced because of a stripped thread. Parts are available to correct this.
And there should be no interaction between the dissimilar metals in this case unless the head gasket were already leaking. As ARCO pointed out, you must have the presence of coolant to make that reaction occur. Without coolant (if the head gasket is still good), then there should be no problem.
This issue is rather common. You can see that Timesert has kits for GM, Ford's modular motors, numerous Honda engine repair kits, and even some Harley Davidson and Volkswagen repair parts.
