Are the transmissions known to have problems? What is the chance of a trans going bad that gets good maintenance?
Their Tranny fluid is awesome stuff. As long as it meets specs I would use it.
Amsoil should guarantee your trans. Call them and tell them your concerns.
This is from the Amsoil site:
1999 MERCEDES BENZ S500 5.0L 8-cyl Engine Code 119.980
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SEO[1]
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFLQT)
Above 5F......15W-40, 15W-50
Above -4F......10W-30, 10W-40, 10W-50, 10W-60
Above 23F......20W-40, 20W-50
All TEMPS......0W-30, 5W-30, 0W-40, 5W-40, 5W-50
Automatic Transmission,722.6......SLF [2]
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Differential, Rear......GLS [3]
ALL TEMPS......
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HBH
AMSOIL Brake Fluid DOT-4 (BF4SN)
Clutch Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
[1] Use only synthetic engine oil formulated to meet
MB Sheet 229.3 or MB Sheet 229.5 or MB Sheet 229.51
[2] ATF 3403-M 115, MB part no. A001 989 21 03 10 or equivalent
[3] Use MB Part no. 001 989 33 03 or 001 989 17 03
or equivalent approved products listed on MB Sheet 235.7
FILTERS:
Oil Filter MANN Oil Filter (H8291x)
Air Filter MANN Air Filter (C33102)
Cabin Air Filter
Cabin Air Filter MANN Cabin Air Filter (CU4007)
Fuel Filter MANN Fuel Filter (WK831)
Transmission Filter
NGK PLUGS AND WIRESETS:
GPSERIES PLUG BKR5EGP NGK7090
IXIRIDIUM PLUG BKR5EIX NGK6341
STANDARD PLUG BKR5ES NGK2460
VPOWER PLUG BKR5E NGK7938
WIRESET WIRESET Direct Fire Ignition [1]
[1] No Wires Req'd
WIPER BLADES:
No Recommendations
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........8.5 quarts [1]
Cooling System, Initial Fill..........17.5 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 722.6 Initial Fill..........Not Specified
Automatic Transmission, Total Fill
5 speed 722.6..........9.1 quarts
Differential, Rear..........3.2 pints
[1] On models with oil cooler, additional oil may be needed when
cooler is drained. Allow 5 minutes after refilling or
turning engine off before checking oil level.
TORQUES:
Oil Drain Plug.....30 ft/lbs
