That white paper drives me nuts! It's hard not to give a fancy white paper like the one from Amsoil a lot of credence. Nonetheless, that particular paper set my Bovine Scatology detector off. It was just too convenient, with RP being Amsoils number one target competitor.
Sometimes, the convenient answer is the true one and in the absence of more independent tests on that level, or at least something similar from RP that counters it, we must accept it at face value. It's hard to believe a big, largely reputable company like Amsoil would fake results. Too easy to prove if they did. If they didn't fake or distort results, the only answers are, A) a bad batch RP oil, or B) the RP isn't all it's cracked up to be. I do think the performance of the oil in the white paper was lower than the results we see in the field and from the few RP gear oil UOAs that surface. I can't help but think there's something "else" here. I have used RP gears oils with good results so far (e.g. my diff hasn't exploded) but at this point, I wouldn't blame an objective person who has been looking at data for not using RP gear oils in favor of Amsoil.
