5w-40 is the classic Euro engine visc. I believe it to be unnecessarily thick in winters. Considering the specific output of that engine, 40 weight is mad overkill. That being said, would I be in a rush to use 5w-40 in it for winter, no. Will it work, yes. Can you get better results with mpg and cold cranking with a 30 weight...
