The original poster didn't mention anything about the motor or the blower. Is this a stock 03+ cobra with the roots supercharged 4v motor?
If so then you don't need something like rotella 5w40.
What did you do to it to get 500 horsepower?
If you have the tune changed, and the air fuel mixture set more rich, then you need a more robust oil and need to change it more often.
If it was stock, I think you would do just fine using whatever ford recommends.
If you have a centrifugal supercharger on there like a vortech, then the blower shares regular motor oil with the engine, and it beats up the oil in very short order.
The roots style blowers have their own self contained oil, similar to turbine oil in airplanes, and other industrial applications.
