Originally Posted By: hounddog
You are making it a peeing contest.Its laughable.AFTERMARKET.I was in the darn trenches everyday with a hundred plus customers a day! That "carbon'issue is what rains down and stops up the oil p'up screen.If the screen has crud the underside of the intake and valve covers do also.No the Magnum don't sludge as bad as the 2.7 but enough of a issue to be ON PAPER of known sludge engines.I didn't MAKE UP THE LIST.Others did.The V6 and BOTH V8 Magnums all do it to some extent.There isn't a 10 cents worth of difference between the 318 and 360.I have seen the innards of dozens upon dozens of these engines.I found that crud in MY valve covers when I installed the Harlan Sharp rockers.Not a lot but it was there.Mine has had BETTER then ideal maintenance.Oh by the way they are also prone to cracking heads and valve guide wear.
Whatever man. Talk about a God complex. I am glad you think working there gives you so much more experienc than I have. Keep telling yourself that.
