Just bought an '09 Ranger, 4.0 SOHC V-6.
It's got around 600 miles on it now, and I'm having the factory fill changed this afternoon at the dealership. (While many people have told me this is probably unnecessary, I've confirmed with two Ford service advisors and a certified Ford tech that it won't be harmful, anyway...)
At any rate, being that this is the first brand-new engine I've ever owned, and I'm planning on running it at least 200k miles, I need to figure out what oil to use.
Ford spec's Motorcraft SAE 5W-30 Premium Synthetic Blend for this truck in the owner's manual. Mobil 1 synthetic, with a 5k OCI, has served me very well in my other Ranger ('97, 2.3 OHC 4-cyl)- it's got about 265k miles, and still runs great with absolutely zero engine repairs. (I got that truck with 200k, and went along with the old adage that "the best oil for an engine with 200k miles is the one that got it there" and it sure seemed to work...)
So I'm more or less down to those two oils (both in the spec'd viscosity, and I will be using Motorcraft filters). Thoughts? If I use the Mobil 1, should I wait until the engine is "broken in" (and if so, how long should I wait?) before I switch to the full synthetic? (I kind of think that's out-of-date advice...but I'm not sure.)
I live in Vermont and don't have a garage, so the vehicle will be started at temps as low as -15 at least a few times each winter. Commute 10 miles to work each day, and rarely make trips shorter than that. Most driving is rural state highways, but some interstate.
Also- I'm sure it's covered here, but I couldn't find it: why does Ford spec 5w-30 for the 4.0 SOHC, while spec'ing 5w-20 for most (or all) their other engines?
