- Joined
- Sep 28, 2002
- Messages
- 39,799
Combustion Chamber Deposit Interference. It's a soft deposit that forms on the piston that eventually has enough mass to hit the head. It's not "destructive" ..but annoying. It's IDENTICAL in symptoms..loud at cold start and retreating with warm up. Piston slap is usually a design characteristic ..not so much an acquired condition. The onset of such symptoms ..to me, anyway ..points to the aforementioned CCDI.
Given that the Triton is not noted for this "characteristic" piston slap issue, it would have me looking elsewhere for things that contour the same symptom profile.
For the sake of a $8-$10 bottle of good fuel system cleaner like Amsoil PI, it would be the first remedy of choice to eliminate one simple potential cause.
It may end up being something else like the chain tensioners or whatnot.
Combustion chamber deposit interference (CCDI) and combustion chamber deposit flaking (CCDF) are two other problems which sometimes occur in certain modern engine designs. CCDI is the result of physical contact between deposits on the piston top and cylinder head and is manifested as a loud, metallic banging sound when the engine is cold. CCDI is limited to the engines that have been designed primarily to reduce emissions, with minimal clearance—one millimeter or less—between some areas of the piston top and the cylinder head (squish areas) when the piston is at top dead center. Combustion chamber deposit flaking causes low-compression pressures to result due to improper sealing of the valves. This problem occurs when pieces of CCD flake off and end up lodged between the valve face and the valve seat. Typical symptoms of CCDF are difficulty in starting and rough running when cold.
