My front brakes have developed an internittent squeal so today I removed the pads to inspect and apply some anti-squeal compound. The pads have no shims. Anyway I saw on one caliper the piston has a chipped piece on the very outer edge of the circumference of the circular piston surface. I was able to remove the chip, its a sliver of piston material, I guess ceramic. The chip is about an inch long and maybe 3/32" of an inch wide. I wish I had a camer to post a pic but I don't. If you can imagine the outer ring of the circular piston, on one side there is an inch long and thin chip knocked out of it.
Does the caliper have to be replaced or can it still be used? I think it would still be able to press out and move the pads and stop like normal. These are the original calipers, have 122K on them now. I have never seen a cracked caliper piston before.
This is probably a really stupid question but I just don't know as much about brakes as most of you do. I can change pads and rotors fairly well and once I replaced the calipers, pads and rotors all at the same time on my old Jeep truck. But I need some info on this before going further with it.
Thanks for any help.
