Retirement advice
by dja4260. 06/18/19 02:10 PM
Oil for DI
by Coastie05. 06/18/19 01:57 PM
Edge or Edge EP for friends Venza
by 53' Stude. 06/18/19 01:11 PM
Found a Premium Blue Restore VOA
by SubyRoo. 06/18/19 12:44 PM
Semi-Syn
by nicholas. 06/18/19 11:30 AM
Particle Count (PC) testing of used oil
by Talent_Keyhole. 06/18/19 11:25 AM
Added individually, coolant & water won't mix?
by Ed_Flecko. 06/18/19 11:15 AM
02 silverado diff fluid....
by Jcountry. 06/18/19 11:06 AM
Arteries
by CourierDriver. 06/18/19 10:17 AM
Remember the Officers
by CourierDriver. 06/18/19 10:02 AM
New TV
by WyrTwister. 06/18/19 08:45 AM
Best cheap filter?
by jayjr1105. 06/18/19 08:37 AM
BB Pistol- The Peacemaker
by CourierDriver. 06/18/19 06:33 AM
Zoro.com 20% off sale
by SubieRubyRoo. 06/18/19 06:24 AM
Why such a low temp thermostat?
by Chris142. 06/17/19 11:21 PM
Abnormal Wear on Tire?
by A_User55555. 06/17/19 11:17 PM
Jag F Type
by Snagglefoot. 06/17/19 11:00 PM
Petethedog, RenewableLubeBen, flattire101, Score294, PublicStellar
68426 Registered Users
106 registered members (bdcardinal, Alfred_B, 928, 53' Stude, aquariuscsm, 11 invisible), 2,176 guests, and 26 spiders.
Topics290,619
Posts4,989,653
Members68,426
Most Online2,967
Mar 10th, 2019
Page 3 of 3 1 2 3
Re: Why do people hate lucas products? [Re: Win] #1722480
12/28/09 04:21 PM
12/28/09 04:21 PM
near the mistake
PT1 Offline
PT1  Offline
near the mistake
Originally Posted By: Win
The Lucas synthetic oil worked well enough in the LS1 in my 2004 GTO, and according to the onboard computer gave slightly (not significant) better fuel economy than some others.
When I removed the Lucas and put in the revered brand "A" wonder oil, it began to lightly piston slap. It never did that on any other oil.
This is one off anecdotal, of course, but I know which one I would use again, and which one I likely will not.
Lucas stabilizer will mask piston slap noise in GM engines. They are still slapping...you just don't hear it. But so will a quart of 40w PYB in a fill of PYB 10w40...try it. I did on 2 engines. But once the viscosity starts to shear the slap comes back.
Oils well that ends well...
Re: Why do people hate lucas products? [Re: demarpaint] #1722484
12/28/09 04:23 PM
12/28/09 04:23 PM
near the mistake
PT1 Offline
PT1  Offline
near the mistake
Originally Posted By: Sunabozu
I've noticed that a lot of people are anti-lucas, why?
I've used the oil stabilizer in my truck religiously and it keeps lifter noise to a minimum. And the fuel additive seems to improve milage.''
So why?
We had a mechanic the used car dept send trades to that prepped them for the line when I worked at a Honda Dealer. This guy swore by the Lucas Oil additive, he threw a qt of it into an engine that had noise. Funny thing was after the customers had the car a while some found the noise came back after an oil change, once the Lucas came out. I heard the synthetic stabilizer is the better of the two. I don't use any of their products by am familiar with them because of this mechanic I knew.
20w50 will have the same effect. Redline 20w50 Motorcycle oil will quiet even the loudest engines.
Re: Why do people hate lucas products? [Re: PT1] #1722490
12/28/09 04:29 PM
12/28/09 04:29 PM
Arkansas
Win Offline
Win  Offline
Arkansas
I didn't, and don't, use their oil stabilizer.
I used their 5/30 synthetic oil, and would do so again.
09 Torrent 3.6 V6 M1 0/30
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 ST Syn 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
Re: Why do people hate lucas products? [Re: Win] #1722508
12/28/09 04:58 PM
12/28/09 04:58 PM
North Palm Beach
38sho Offline
38sho  Offline
North Palm Beach
also on the nice little lucs stabilizer store displays.......
notice which one spins MUCH faster and smoother....... the one without the Lucas.....
fools don't even realize the other one still has oil on it but does the intended job of the gears/motor much better.....
93 Taurus SHO
Mobil 1 0w-40 and M-301 oil filter
Re: Why do people hate lucas products? [Re: 38sho] #1722728
12/28/09 08:56 PM
12/28/09 08:56 PM
Florida
artificialist Offline
Florida
I wouldn't use Lucas on a newer vehicle that works well.
However, I have seen great results by putting Lucas PSF in failing power steering systems, and Lucas ATF additive in failing transmissions.
However, I wouldn't use it in newer good vehicles because of foam.
2010 Lancer Ralliart Sportback
Re: Why do people hate lucas products? [Re: artificialist] #1722737
12/28/09 09:07 PM
12/28/09 09:07 PM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
I don't necessarily hate Lucas, I just don't find values in them given their pricing and rather aggressive promos...
Q. drive
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Why do people hate lucas products? [Re: Quest] #1722845
12/28/09 10:32 PM
12/28/09 10:32 PM
Buffalo, NY
JTK Online content
JTK  Online Content
Buffalo, NY
I don't see a single mention of Lucas UCL fuel add in this thread. As far as I know it serves the same purpose as any other add you dump in your tank.
Joel
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Why do people hate lucas products? [Re: JTK] #1722954
12/29/09 12:14 AM
12/29/09 12:14 AM
PA
Audi Junkie Offline
Audi Junkie  Offline
PA
duh
2008 Opel Astra 1.8 VVT 5M
2010 VW Tiguan 2.0 TSI 6M
(APR Powered)
Re: Why do people hate lucas products? [Re: andyd] #1723049
12/29/09 03:02 AM
12/29/09 03:02 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Originally Posted By: andyd
I used about a pint of the Lucas oil additive as a cam lube when I R+Red the head on a CRV. It worked fine for that purpose, but it was no where near as tacky as STP which I have used in the past on OH cams.
As an assembly lube, it's OK.
Last turbine overhaul we did, we needed the shafts (60T, sitting on 2 bearings) installed before the lift oil was available.
Lucas did a great job, drizzled down the direction of rotation, once the shaft "cracked", it moved very easily, and didn't squeeze out. 4 rotors, 8 bearings, and 200T of metal, and we used about half a quart of Lucas for about 4 days of re-assembly.
Shafts normally run at 3,000 RPM on 60C ISO32.
I use Lucas UCL religiously. (not on the turbines)
If it's the truth....it can handle the pressure !!!
Re: Why do people hate lucas products? [Re: Sunabozu] #1723802
12/29/09 06:04 PM
12/29/09 06:04 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
i would almost bet lefty that motor oil can not cavitate inside the oil pump.
can motor oil even do that, uh, ever?
edit: even if it could, why would making the oil thicker reduce the vapor pressure?
Timing gears, which aren't submerged are another area of possibility. Transmissions, rear-diffs like Bob's test.
Also, oil pumps can, and DO cavitate. This is why anti-cavitation pumps exist.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Why do people hate lucas products? [Re: OVERKILL] #1724555
12/30/09 09:42 AM
12/30/09 09:42 AM
Ohio
HighViscosity Offline
Ohio
I don't see too many vehicles in the sig line with over 300k miles on them. Most people don't keep their cars as long as they think they will. It's that overly optimistic view that leads some to add magic tonics to their vehicle in the hopes of auto immortality. The data on this site and others prove that modern engines well maintained usually last the life of the car. Any attempt to "make things even better" usually just results in a thinner wallet for the owner and sometimes detrimental effects to the engine.
Just like the Lucas thick oil demo at the parts counter, it is designed to dazzle the stupid by implying that your car needs much thicker oil than the manufacturers and oil companies provide.
I did a little experiment last year with my motorcycle where I removed the spark plug and noted the appearance of the piston. I next ran a tank of fuel mixed with Redline SL1, then a tank with Seafoam, then a tank with Lucas UCL which also claims to clean the combustion cylinder. Initially the piston crown had a satin black appearance. After the Redline the carbon was reduced with a few spots of metal reflecting light. Then after the Seafoam the piston improved further reducing carbon by approx 40%. Lastly, I added the Lucas UCL. Now my piston had a sooty black appearance uniformly covering the piston crown.
Even if Lucas does offer an un-needed increase in lubrication, it's negatives outweigh any perceived benefit in my opinion. It is like making your engine simulate being an oil burner. Lucas UCL is a petroleum distillate that has the consistency of motor oil so why would one assume it would burn cleanly without residue. Adding 2 cycle oil may offer some benefits, but shouldn't be needed by most people.
Last edited by HighViscosity; 12/30/09 09:46 AM. Reason: BITOG user interface sucks
I said Dance! shoot...................... happy
These are the good old days!
Re: Why do people hate lucas products? [Re: HighViscosity] #1763614
02/01/10 12:35 AM
02/01/10 12:35 AM
TN USA
pondfishr Offline
pondfishr  Offline
TN USA
If their products are so bad how did they earn enough money to sponsor the Colts football stadium? Just a thought.....
Re: Why do people hate lucas products? [Re: pondfishr] #1763622
02/01/10 12:51 AM
02/01/10 12:51 AM
PA
Audi Junkie Offline
Audi Junkie  Offline
PA
I think the answer is *self* evident.
(APR Powered)
Re: Why do people hate lucas products? [Re: Audi Junkie] #1763629
02/01/10 01:04 AM
02/01/10 01:04 AM
TN USA
pondfishr Offline
pondfishr  Offline
TN USA
Interesting
Re: Why do people hate lucas products? [Re: pondfishr] #1763660
02/01/10 02:12 AM
02/01/10 02:12 AM
Long Beach, CA
robbobster Offline
robbobster  Offline
Long Beach, CA
I don't have an opinion about Lucas, but even Enron had naming rights to a stadium at one time.
2014 Volt
2010 Prius
Page 3 of 3 1 2 3
