'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
34 registered members (Bailes1992, ChrisD46, ArrestMeRedZ, ctechbob, billt460, Dave9, 2 invisible), 551 guests, and 56 spiders.
Topics286,049
Posts4,901,475
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
silicone spray rubber to extend life? #1721161
12/27/09 11:14 AM
12/27/09 11:14 AM
Boston
lairdwd Offline OP
lairdwd  Offline OP
Boston
Does anybody spray their rubber components with silicone spray? For example, once a year I spray the CV boots with silicone, as well as the rubber gaskets around the doors/trunk/hood. Original CV boots lasted 16 years and 180K before they finally split open, so it seems to have paid off.
Was wondering if anyone sprays any other rubber components? I can't really think of anything else that gives a good bang for the buck here besides the CV boots and exterior gaskets.
Re: silicone spray rubber to extend life? [Re: lairdwd] #1721177
12/27/09 11:25 AM
12/27/09 11:25 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
On the old mb diesels, most are starting to crack after 25-30 years and >200k without silicone.
Still, if it doesn't swell or degrade the rubber, I'd imagine it is a great idea.
Re: silicone spray rubber to extend life? [Re: JHZR2] #1721183
12/27/09 11:31 AM
12/27/09 11:31 AM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
Don't see it would help the situation for rubber components (except EPDM) such as suspension bushings, strut boots, etc. will deterioriate over time due to (a) ground ozone; (b)heat (c)contamination such as grease/oil/hydrocarbon based stuff.
Esp. CV boots where typically it would suffer from all of the above. So long as you service them (repack) when you see a crack developing and so on, it should still lead an easy 200,000miles life (1 or 2 repacking required).
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: silicone spray rubber to extend life? [Re: Quest] #1721216
12/27/09 12:05 PM
12/27/09 12:05 PM
Michael_P Offline
Michael_P  Offline
I've occasionally sprayed silicone on all the rubber on my vehicles. On CV's it seemed to extend the life on them. As to the door seals, it works great in the winter unless you have someone who gets in and out of the vehicle in a long coat and the coat wears up against the door seal. My mother in law drags her coat up against the door seal on her car and the silicone softens the rubber making it less abrasion resistant (my experience). As a result, I replaced the door seals and quit using silicone. On my cars, I silicone the door seals because no one drags their coat against the door seals. Silicone is awesome for cars left outside in freezing rain. It stops the seals from sticking. For EDPM suspension bushings, I do not recommend because it tends to cause the EDPM to separate from the metal case on the bushing by softening the vulcanization. I have had bushing separate that were frequently siliconed. Some silicone sprays are below 7 on the PH scale which means they could be corrosive. I always use a food grade silicone which ensures me of PH neutrality.
Re: silicone spray rubber to extend life? [Re: Michael_P] #1721230
12/27/09 12:17 PM
12/27/09 12:17 PM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
why try stretching the service life of a cv boot when the rotting comes from the inside and not outside? (outside is strictly cosmetic and bears no useful signs/meanings to that of whether the inside is holding up properly or not. It's just psychological).
Also: EPDM rubber typically used in weatherstripping seals and not on suspension bushings.
LAstly: silicon spray doesn't stay on very long for it will wash out fairly quickly. It's only good use is for assembly of parts.
Re: silicone spray rubber to extend life? [Re: Quest] #1721274
12/27/09 01:11 PM
12/27/09 01:11 PM
PA
mikered30 Offline
mikered30  Offline
PA
Is silicone better than 303?
Re: silicone spray rubber to extend life? [Re: mikered30] #1721288
12/27/09 01:28 PM
12/27/09 01:28 PM
beaver land EH?
Quest Offline
Quest  Offline
beaver land EH?
Nothing will stop the deterioriation of CV boots, nothing. So don't bother spraying with Amror-wall, 303 and the likes for it's an utter waste of time.
Although some CV boots tend to stay good longer due to the composition of plastics (some thermal plastic blend as opposed to synthetic rubber), they will still go through the usual stages of deterioration (heat from the inside, for example) and they will all go eventually.
Q.
Lemme see: I've tried all kinds of tricks to extend my 323 and my Suzuki's CV boot life: from keeping the steering knuckle aligned (steering wheel straight during parking) to spraying on 303/armourall to sylglide, etc. none of them can stop the deterioriation or extend the life of my boots and they all eventually go bad to the point where I have to repack them around 130,000kms or 8~11yrs. Since then I learned the fact that it's not only heat but ground ozone that would exacerbate the situation of the boot so I wouldn't bother to protect it now but to inspect it every year or during brake servicing, and whenever I see slight cracks developing on the crease of the boots, I'll take them off and repack with a fresh new boot kit and life goes on.
Re: silicone spray rubber to extend life? [Re: Quest] #1721309
12/27/09 01:54 PM
12/27/09 01:54 PM
Afghanistan
Captain_Klink Offline
Afghanistan
there is no other good product for it, so i silicone spray all of the rubber door seals on an annual basis. i don't know if it does any good or not, but it makes me feel better anyway. i do it in the fall, and it helps to keep the rubber from freezing together when we get a thaw followed by a freeze.
Re: silicone spray rubber to extend life? [Re: Captain_Klink] #1721344
12/27/09 02:32 PM
12/27/09 02:32 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Silicone etches glass. I heard of Talc-ing door surrounds.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: silicone spray rubber to extend life? [Re: ARCOgraphite] #1721374
12/27/09 03:06 PM
12/27/09 03:06 PM
Chicago IL
ChiTDI Offline
ChiTDI  Offline
Chicago IL
Door surrounds and all that rubber frame insulation can be well protected with a product call Gummi Pflege.
Goes on with a built-in daubber like old fashioned shoe polish.
Stuff works great and your doors will open when the car comes out of a Dr. Zhivago icestorm.
Re: silicone spray rubber to extend life? [Re: ChiTDI] #1721607
12/27/09 07:52 PM
12/27/09 07:52 PM
Afghanistan
Afghanistan
found it!!! it's called 3D Universal protectant.
One gallon on Amazon is 20$ + shipping. water based thick silicon, you put it on your sponge, spread it on, let dry, then wipe off. and it's good for everything, even tires - makes them really shiny.
Re: silicone spray rubber to extend life? [Re: ChiTDI] #1722591
12/28/09 06:15 PM
12/28/09 06:15 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
Silicone etches glass? Never heard of that one!
BTW, good luck finding a silicone spray with more than a pittance in there. Most are light oils with some silicone.
But yes, anything is better than leaving seals alone. Armor all or any similar treatment is a help in the right direction.
Re: silicone spray rubber to extend life? [Re: ChiTDI] #1723253
12/29/09 10:45 AM
12/29/09 10:45 AM
Chicago IL
ChiTDI Offline
ChiTDI  Offline
Chicago IL
Re: silicone spray rubber to extend life? [Re: ChiTDI] #1723441
12/29/09 01:31 PM
12/29/09 01:31 PM
Ohio
Tdbo Offline
Tdbo  Offline
Ohio
Napa Sil-Glyde. It takes some rubbing to get it on the rubber but it lasts. For <$6 a tube it is hard to beat.
2012 Honda Accord LX-P 95K
2008 Ford Mustang Pony Package Convertible 17K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 116K
Re: silicone spray rubber to extend life? [Re: Tdbo] #1723526
12/29/09 02:33 PM
12/29/09 02:33 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
Being a snake oil freak, I think I'll check out the Napa stuff.
Page 1 of 3 1 2 3
