I ran Rotella 10-30 for 8 years, and 210,000 in my Mercury Villager. It is also a diesel rated oil. There was no cat poisoning involved, and the van passed an emissions test every year. If your vehicle burns oil, the higher levels of P (of the additive ZDDP) MAY poison the cat, and make it ineffective. The flip side of this is that the higher level of anti wear additives, and cleaning agents in diesel rated oils can keep wear down, and keep the engine cleaner to start with, avoiding the situation of oil consumption in the first place. The final decision rests with you, but the diesel rated oils are very good, and the cat poisoning issue is based on an individual situation. Your Saturn would be fine on the 15-40 varieties also if the temps are above about 20 degrees. BTW, Rotella 10-30 is available at all my local WM. There is another thread on the site about Delo 10-30, and you will find Delvac 1300 in 10-30 at Truckpro outlets.
