I'm wondering what the general recommendation is for oil in this transmission? I bought some Valvoline Max Life full sythetic a while back and was considering using that. It says it meets the spec for the transmission. I was going to drain all I could a few times since I don't have the proper machinery to do a thorough flush. I believe 3-4 quarts may drain out at a time although it holds 7-9 quarts. Is this an acceptable approach? Will the Valvoline Maxlife not mix properly with the OEM Ford oil?
