Originally Posted By: 02zx9r
so if I am using mmo regularly, would it be worthwhile to use a fuel injector cleaner on my trip to Louisiana this Saturday? Thinking of running a bottle on the way down in a tank of gas and maybe one on the way back. It is 1600 miles each way, will be down there for two weeks then head back
I'd run the FI cleaner, MMO does clean up injectors, FI cleaner is better at doing it. In fact they suggest a FI cleaner, then use MMO to keep them clean, lubed, and work as a UCL. I think a long trip would be the perfect conditions. I'd skip the MMO for the tank with the injector cleaner, then once your done start adding the MMO again. JMO
I definetly agree with Demarpaint on this one, run the fuel injector cleaner in the tank with no MMO, and then on your next tank of gas you can start using the MMO.
