more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
74 registered members (alarmguy, Astro14, 1foxracing, b1amgm47, AurionX2, 2 invisible), 1,454 guests, and 53 spiders.
Topics286,271
Posts4,905,701
Members67,589
Most Online2,967
Mar 10th, 2019
Anyone use Engine Release siezed engine lubricant? #1707496
12/14/09 07:35 PM
12/14/09 07:35 PM
Orygun
ssenter Offline OP
ssenter  Offline OP
Orygun
I did a search and haven't found a reference to this product -"Engine Release" - anyone use this product and what were the results?
I have a '69 Chrysler 383 that has sat for almost thirty years (supposedly in a garage). Engine hasn't responded (yet) to a combination of WD-40, PB blaster,MMO w/ a 3/4" and breaker bar. Engine oil analysis only showed water and lead above average- what I would expect for an engine last run in '79, i.e. condensation and leaded gas...
Thanks a bunch!
Scott
Re: Anyone use Engine Release siezed engine lubricant? [Re: ssenter] #1707557
12/14/09 08:16 PM
12/14/09 08:16 PM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
What your have used is good, I would not bother with trying the engine release. You may want to fill each cylinder with Diesel fuel and let it soak. If that does not work, you are going to have to go in. Nice thing the old moters are easy to work on...
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Anyone use Engine Release siezed engine lubricant? [Re: Bluestream] #1707628
12/14/09 09:05 PM
12/14/09 09:05 PM
USA
JohnBrowning Offline
USA
Generly if PB blaster sprayed into the cylinders does not do it nothing else will. I am sure I do not need to tell you what 30 years of rust looks like when it is going from the blco throught rings right up to the groves inthe piston becasue the piston has carroded while the metal was rusting.
I have heard of the product on Horsper TV but they plug something new each week so who knows if it is any better then what you have already tried. What you probably need is a mild acid solution say 3-5% Sulferic Acid commonly sold as Muratic Acid at Hardware stores. You can mix it with oilsmall amount of light weight oil. Just do not go dumping straight acid in their it will eat the pistons and you just want to eat away some of the rust. You could also use Phsphoric acid which is used in Soda or Pop and also used by body shops to eat off rust and etch the surface. The acid will attack everything not just the rust. If you use a straight product like bulk phospheric acid as sold to body shops and fill each cylinder I wouldnot let it sit more then 15 minutes before trying to crank. Make sure you put a towel over the plug holes so acid does nto shoot every place and damge paint and such!Mind you all of this is last resort to tearing the engine apart and beating the pistons out with a wood block and hammer!
Re: Anyone use Engine Release siezed engine lubricant? [Re: JohnBrowning] #1707641
12/14/09 09:18 PM
12/14/09 09:18 PM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
If the engine is stuck that bad, the cylinder walls are going to need to be reconditioned. Even if you got it running, it's not going to last or run well with rusty cylinders. Those motors are easy to work on and lots of fun to re-build
2006 Pathfinder 4X4
1991 BMW 735iL
Re: Anyone use Engine Release siezed engine lubricant? [Re: Bluestream] #1707997
12/15/09 09:01 AM
12/15/09 09:01 AM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
One thing to keep in mind: I have worked on old engines that have sat for years, and often its the valves that are stuck/rusted. If you do get it to turn over, be carefull of piston to valve contact as they bend very easy
2006 Pathfinder 4X4
1991 BMW 735iL
Re: Anyone use Engine Release siezed engine lubricant? [Re: Bluestream] #1708083
12/15/09 10:42 AM
12/15/09 10:42 AM
Florida
416Rigby Offline
416Rigby  Offline
Florida
You might try some Kroil in the cylinders. If that doesn't loosen it, nothing will.
Re: Anyone use Engine Release siezed engine lubricant? [Re: ssenter] #1708213
12/15/09 12:02 PM
12/15/09 12:02 PM
East of IGO
Steve S Offline
Steve S  Offline
East of IGO
Thanks a bunch!
Scott
Penetrating oil will help go for it!!
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
Re: Anyone use Engine Release siezed engine lubricant? [Re: ssenter] #1709245
12/16/09 09:00 AM
12/16/09 09:00 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Thanks a bunch!
Scott
Welcome to Bitog! Someone already mentioned Kroil, a great product. Heat and Vibration are very helpful as well. Do a piston soak with Kroil, hopefully you have the engine on a engine stand. If so, see if you can put a heat lamp or portable electric heater under the engine. JUST BE CERTAIN IT CAN'T CATCH FIRE. Once the cylinders are filled with Kroil, take a rubber dead blow hammer and bang the side of the block near the spark plug holes. [At this point remove the heat source, you don't want Kroil dripping onto the heat source]. This will set up vibration and help the Kroil creep down. If the engine is rusted up solid it is going to have to be rebuilt, but this will certainly help get the pistons out.
God Bless Our Troops
Re: Anyone use Engine Release siezed engine lubricant? [Re: demarpaint] #1869299
04/24/10 12:51 PM
04/24/10 12:51 PM
Kah-nah-dah
gamefoo21 Offline
gamefoo21  Offline
Kah-nah-dah
If you can't get ahold of Kroil,
Diesel fuel will break rings free. My dad swears by it, just let it soak for awhile and it should roll over.
Or you can try the 50/50 mix of ATF/Acetone.
