For all you BITOG'ers who like to see more info on this suject,
check out the Nov. 09 issue of Hot Rod magazine. Performed dyno pulls on a 372 CID Dart small block Chev using 5 different oils. 30W dino and 20W-50, 5W-20, 0W-20 (race oil), and 0W-10 (race oil). All Lucas oils. HP average was from 3,100 to 6,500 RPM.
viscosity peak HP avg. HP PSI GPM peak temp(F)
30W 475 383.9 67.1 6.1 162
20W-50 477 387.0 67.4 6.5 163
5W-20 479 386.3 59.4 7.2 166
0w-20 (race oil)478 387.5 59.7 7.4 166
0W-10 (race oil)480 387.4 55.7 7.4 165
Lucas reps stated that race oil was designed for 8,000 RPM plus and would show no advantage until then. I was surprised that the 20W-50 was only 1 HP shy of the 0W-20. Also note that the 30W has the lowest oil temp. The testers felt that a syn 5W-20 would be the best compromise for a HP street engine. It was their opinion that high flow at a lower PSI was best.
Interesting
Interesting
