Originally Posted By: redraiderfan
After reading here I used MMO as directed in my fuel and my Check engine light came on within 10 miles or so. 2009 Chevy Cobalt 2.2 XFE
I took it to the dealer and they said MMO has Phosphorus in it that will damage 02 sensors and catalytic converters that especially OBD III systems can detect it at too high a level.
I stopped using it and next fuel fill the light went out using FPPLUS from Odis Beaver as recommended by Terry Dyson.
I will NOT use MMO in fuel for a newer car. I dont' think I will use it in the motor oil unless I see UOA that proves it does no harm.
1988 Ford E-150 4.9L original cat converter, saw MMO since day one. In 1990 I hooked it up to an inverse oiler and used that until about 2 months ago when I thought it wasn't metering oil properly. Trust me if it ruined cat converters I'd know from real world not a lab test. 1985 E-150 4.9L sold with 150,000 miles on it original cat converter, and O2 sensor. No issues. 1990 Ford Aerostar 179,000 miles original cat converter and O2 sensor, MMO since 50,000 miles when I bought it.
I think it was a coincidence in your case. But if I were you I'd use something else if you don't like MMO.
Odds are since it was brand new I think there was some other issue that triggered the CEL, not the MMO. Easy for the dealer to blame something, if you mentioned any fuel additive they would have said the same thing. I worked in car sales and was buddies with the guys in the shop, I heard them all.
