In the serviice manual they show those side floor/pinch weld parts that you can see the metal sticking out. Civic was on a 2-pole lift earlier and worked fine, as the lift had a flat foot on all 4, and they have 4 plates sticking out the pinch weld.
My jackstands are the 6 ton type but have that sort of U shaped axle type support. Where can I set these to safely support the car and how do I do it. I think if I put them on those weld spots, the weld spots wouldn't touch because of the U shape.
Would it be completely dangerous to dry and make some type of cylinder elongated rubber things to stick between the pinch welds and the support in the jackstand? Hockey Pucks?
