Reviving this old thread as I only came across this idea last night - yet there's so much good discussion here it shouldn't (IMHO) be buried as deeply as it was. I didn't read the entire thread, but read enough to be convinced of the value of tcw3 as a very inexpensive (500:1 ratio means using tiny quantities of it), easily attainable, and worthwhile fuel additive to try.
So I hit Walmart tonight and grabbed a half liter bottle of the Castrol brand. It was either that or Supertech, but for the small difference in price, the Castrol version won out because it stated clearly on the back of the bottom that it was ashless (the Supertech bottle said instead "low ash"). Also I liked the design of the Castrol bottle for this application: it has a see through stripe down the side, and its marked at every half ounce and 50 ml increment - which makes measuring the small amounts of this out simple.
I estimated, based on my known average mileage and trip meter since last fill, how much gas I'd burned since that fillup and therefore what remained in the tank. I rounded it to 24L, which at a 500:1 desired ratio, meant 48 ml of oil. I rounded that up to 50 and, using a funnel, poured 50 ml from the Castrol bottle into an old empty Prestone fuel injector bottle I still had in the trunk (for future reference, I will be keeping my next empty Regane 2x bottle as its perfect for this). I then emptied that into the tank and took the 'rolla for a short spin to get it sloshed up a bit.
The noticeable difference right away: at high rpm (just before the auto shifts), the engine has a deeper, throatier resonance. Its not unpleasant. A little surprising coming from a 1.8L 4 cylinder, but it doesn't sound "riced" or like the muffler is missing or defective.
No noticeable impact on acceleration or power, which is all good. This little 500 ml bottle should go a long way in my 50L gas tank, but when I run out I can obtain the same stuff for a little more than half the price in its 4L bottle size. If it delivers what those in threads say it does (and I'm inclined to believe them), its worth adding to every tank imho (at least until MMO is sold locally at as cheap a price per application).
-Spyder
