Originally Posted By: SteveSRT8
Originally Posted By: mechtech2
Easy break in is not a myth.
Umpteen jillion cars have had an easy break in s with wonderful results.
And an easy break in just contributes to the issue mentioned.
We have a 3rd gen machinist in our family who builds mega bucks motors all the time, just set up a 630 cubic inch street motor. 20k for the crate motor and 15k more after that!
He says all the [censored] about easy break in is a myth based on old time manufacturing. Did anyone read the Chrysler manual? It says full throttle is beneficial. And there's tons more to back this up. This is really no different than the people who think a motor can't break in on synthetic.
It's like this... the rings are seated in seconds or minutes. The rotating assembly is either right or not. Why not break it under warranty?
More blow by in easily driven motors means more [censored] in your oil. At least you BITOG'rs ought to get that!
I agree whole heartedly with your post.
Some people do take break in too extremes and actually they are not doing themselves any favors( this is not directed at the OP of this thread ).
When I used to build motors for my muscle cars and hot rods( no mega $$$ monsters like your family member but I did ok for a DIY'er ) I would start it and let it idle for like 10 minutes before heading out for a ride. I would take it easy for the first say 50 miles just to let everything seat and wear in. It was also to make sure I had done my job right building the engine and hooking everything back up properly. If everything went ok for 50 miles I was good to go.
During that 50 miles I would drive around calmly, varying the speeds up to 60'ish, before I would start doing some short runs( not quite WOT - maybe 3/4 )after reaching that 50 miles. I never red lined during that 50 miles period, and really I didn't after that until I reached my break in mileage limit, but the RPM's got up there a few times after that 50 miles was reached. Like the Challenger manual talked about I would get into it for short bursts.
I wouldn't do l-o-n-g sustained WOT runs for the next say 300-400 miles give or take but I used the engine like it was going to be used. I think the break in procedure listed in the Challenger's manual is a good one. Very similar to how I did it. I never had any problems with failed engines nor oil consumption. I even broke them in on synthetic. Lord I am lucky they made it to the end of the street I guess.
Babying a performance engine for 1000 miles and then starting to beat on it can lead to what has happened to the OP. Use it like you plan to pretty much from the get go. You shouldn't take it from the engine stand to the drag strip if the engine will be in a vehicle driven regularly on the street but don't baby it too much either. Just use common sense and don't go nuts right off but you need to use it like you plan on using it after the break in.
