Originally Posted By: Mustang2008Z
All I want to do is follow what is in the manufacturers' manual. If it calls for 5W-20, SM/GF-4 API Certified, then I follow it, if it calls for 5W-30, SM/GF-4 API Certified, then I follow it.
I follow all of the miles/months needed for services, and get them done by the dealer on time so that the mfgr knows that I followed their recommendations on my car.
I keep all of my maintenance records, and should I have any problems with the manufacturer about warranty issues, that repairs will not be covered, then I will keep the original invoices showing what was done when, mileage, and what oil was used, etc, etc., then I will make copies for the dealer and the mfgr for their records, then any repairs will be covered under the warranty.
That way there is written proof for all to see.
Many years ago, when I had engine problems with my Ford F-150, I took my truck in for repairs, and after the dealer saw my written records and contacted Ford, the warranty was honored and it cost them a new motor.
Same thing happened, when I had a Cadillac Seville, too, the dealer was all excited about how much I was being billed for some serious engine and transmission repairs, and was amazed at how fast I signed the order to have the repairs done, then, bingo, I told them it was under General Motors Warranty, they went and checked it out, and lo and behold, everything was under warranty, they changed the order for repair showing that it was under warranty, and it cost me $0.00. GM was stuck with the repairs and they honored the warranty.
You can do that if you know for sure you have a good and honest dealer that does oil change for you. But, even if you do, when you are out of warranty, and your car is worn, then no one but yourself would foot the repair bill.
I've been using a "reputable" dealer for a long time, and my latest find is that their OEM oil filter is not any better than FRAM, which has paper endcaps, and the mechanic who did the oil change did not bother to replace the oil filter. He did not rotate my tires when I asked to but svr writer claims he did.
Problem is that we need use our own brain to think what's making sense. Truth is every car must accept multiple oils. They may not state it in the owner's manual, but it's definitely in the workshop manual.
