Originally Posted By: Jason Adcock
The intake floor on mine has some residue on it, but oil isn't puddled. It idles perfect and runs good. There is some heavy throttle spark knock. My engine does not have EGR, so I can rule that out as the cause of the spark knock. Spark knock is a common symptom of the bad plenum gasket, but mine doesn't use any oil (that's also a symptom) and it otherwise runs fine, so it may be another issue (like carbon maybe). I've never Seafoamed this engine or anything since I've got it. Just kept the oil changed.
FastSUV, you said before in another thread that you thought you liked the Pennzoil HM better than the Valvoline ML? I've run a lot of SOPUS stuff, including PYB and PP, but I've never ran that PHM, for whatever reason. Can you explain some more why you like it better than the VML? I've always had good service from the VML in this truck, but that's not to say that the PHM couldn't be an improvement.
Max-life made the engine more sluggish and MPG went down slightly. I believe the Pennzoil HM to have less moly than Max-life. This was on my flat-tappey 4.0L and it ran quieter than with Maxlife...I know Maxlife would serve it well, but my perception was the Jeep ran better on the Pennzoil HM because I did a fill of it, then the very next fill was Maxlife so I compared them in back-2-back OCI's. I liked it so much I filled my magnum V8 with Pennzoil HM to try it over M1-HM...since the M1 tends to leak more, I figured I'd give it a try since it served my other Jeep well.
