Originally Posted By: Drew99GT
Originally Posted By: rudolphna
Ahhhhh, thanks drew that makes sense, I hadn't though of that... That seems like it should be a fairly easy problem to fix though, doesn't it? Why not vent the PCV somewhere else? Like oh, I dunno, into the engine bay? Or something....
The common fix for DIY gearheads is a catchcan/oil separator for the PCV system. I think some OEMs use them with an automatic drain system that drains back into the crankcase.
not only that, but add on ones are exempt from the smog inspection since they actually help emissions.
