Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
78 registered members (Astro_Guy, aquariuscsm, alarmguy, bcossa2001, avi1777, Back40, 9 invisible), 1,005 guests, and 50 spiders.
Topics286,106
Posts4,902,702
Members67,563
Most Online2,967
Mar 10th, 2019
Page 1 of 8 1 2 8
Recommend Trans fluid that meets Honda ATF-Z1 #1631140
10/14/09 08:33 AM
10/14/09 08:33 AM
MA
mez Offline OP
mez  Offline OP
MA
What off the shelf synthetic Transmission fluid would you recommend in lieu of using Honda ATF-Z1? I was thinking of using Mobil 1?
2006 Honda Ridgeline RTL
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: mez] #1631145
10/14/09 08:38 AM
10/14/09 08:38 AM
Kansas City
Hermann Offline
Hermann  Offline
Kansas City
If you are dead set against using the Z-1, probably Amsoil. It is the only alternative that seems to please the users who switch.
2018 Ford F-150 XL Reg Cab - 3.3L NA V-6
Motorcraft 5w-20 Syn Blend and Motorcraft FL-500s
1991 BMW R100GS 20w-50 Maxlife & Mahle OX36D filter
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Hermann] #1631165
10/14/09 08:50 AM
10/14/09 08:50 AM
Milwaukee, WI
bepperb Offline
bepperb  Offline
Milwaukee, WI
There are several. M1, Amsoil, Castol Import. There don't seem to be bad experiences, or at least not any more than there would be with Z1.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Hermann] #1631167
10/14/09 08:51 AM
10/14/09 08:51 AM
Virginia
Familyguy Offline
Familyguy  Offline
Virginia
They don't have any Honda dealers in MA? You can also get it at a Saturn dealer (until they fold up their tents) since 1st generation Saturn VUEs with the 3.5L Honda engine used Honda Z1 fluid. The Saturn dealer will have repackaged Z1, though I can't remember the part number offhand.
2013 Kia Sorento EX
3.5L AWD
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Familyguy] #1631173
10/14/09 08:58 AM
10/14/09 08:58 AM
SE Michigan
94MaxGXE Offline
94MaxGXE  Offline
SE Michigan
When the time comes for my 07 Honda, I think i will try Valvoline MaxLife DEX/MERC ATF.
Specs
Recommended for use where the following fluids are specified:
Ford MERCONŽ, MERCONŽ V, MERCONŽ SP and LV
GM DEXRON, DEXRON II, III and VI
Toyota and Lexus Type T, T-III, T-IV and WS
Allison TES 295 and 389
Nissan Matic-D, Matic-J and Matic-K
Honda and Acura ATF Z-1 (except CVT)
Mercedes NAG-1
Mitsubishi Diamond SP-II and SP-III
Kia SP-II and SP-III
99 Camry 144K SOLD
07 Accord 130K Miles
08 MazdaSpeed3 44K PP
10 Subaru Outback Gone
10 Mazda3s 95K
94 Nissan MaximaGXE 125K Sold
2012 Equinox 58K Gone
2016 Honda CR-V
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: 94MaxGXE] #1631188
10/14/09 09:15 AM
10/14/09 09:15 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I don't have Hondas but the M1 ATF has worked well for me. I started using M1 ATF when Mobil first produced it. Here's the link.
https://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: tig1] #1631235
10/14/09 09:55 AM
10/14/09 09:55 AM
Calgary Canada
Jim 5 Offline
Jim 5  Offline
Calgary Canada
Pennzoil has an import multi-vehicle ATF that says recommended for Honda and Acura ATF Z-1 (except CVT).
I think I'm going to use the Mityvac and suck out a gallon at every oil change and replace it with the PZ stuff. I'll post results.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Jim 5] #1631281
10/14/09 10:51 AM
10/14/09 10:51 AM
Minnesota
nfs480 Offline
nfs480  Offline
Minnesota
I've been putting the Amsoil Synthetic Universal ATF in my Honda's and it's been working fantastically.
1989 Honda Accord SE-i 238,000 miles Amsoil ASL 5W-30.
2011 Honda Fit Sport 14,000 miles Amsoil XL 0W-20
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: nfs480] #1631289
10/14/09 10:55 AM
10/14/09 10:55 AM
Retired | Wausau, WI
Johnny Offline
Johnny  Offline
Red Line D4 works well in my Element.
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Johnny] #1631296
10/14/09 10:59 AM
10/14/09 10:59 AM
Calgary Canada
Jim 5 Offline
Jim 5  Offline
Calgary Canada
Surprised you're not using PZ's Import MV ATF!
Jim A
66 Bronco QS 10w-30
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Jim 5] #1631310
10/14/09 11:10 AM
10/14/09 11:10 AM
Johnny Offline
Johnny  Offline
If I did not have to buy it buy the case, I would. No one around me sells it by the quart and it only takes 3.5 quarts to drain and fill the Element.
I might add my wife's Element has the Amsoil ATF in it and it also works well.
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Johnny] #1631684
10/14/09 04:07 PM
10/14/09 04:07 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Maxlife seems to do well in my Integra, then again, probably many import MV ATF especially those that meet JASO A1 will do.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: PandaBear] #1631759
10/14/09 04:59 PM
10/14/09 04:59 PM
Washington St.
Ken2 Offline
Ken2  Offline
Washington St.
The only fluid that meets the Honda spec is Honda's own fluid.
The other fluids are "recommended" by the oil maker for your car. They'll likely do a find job, but they have not been tested and do not meet the spec.
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: Ken2] #1631792
10/14/09 05:24 PM
10/14/09 05:24 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
There are countless Honda Odyssey owners using Valvoline Maxlife ATF in thier Z-1 spec'd Odys. Maxlife is a "suitable for Z-1 use" ATF per it's specs. Obviously none are going to be approved by Honda. Keep in mind the Odyssey has probably the worst track record in regards to transmission longevity and Maxlife does excellent in them. There's not a single failure report of one running Maxlife that I've seen.
Joel
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Recommend Trans fluid that meets Honda ATF-Z1 [Re: JTK] #1631981
10/14/09 08:00 PM
10/14/09 08:00 PM
ohio
caravanmike Offline
caravanmike  Offline
ohio
Joel
+1
Oils I use: Any 5w-30,5w-20 conventional
Page 1 of 8 1 2 8
