OVERKILL
$100 Site Donor 2021
Originally Posted By: INDYMAC
I find this VOA useful since I use a maintenance dose (3-4ozs) of ARX, and I do used oil analysis. When you are splitting hairs on single digit wear numbers, it's good to know that some of the results may have come from ARX (contamination). The flash point is low, and the insolubles are high with a low viscosity. I can take all of this into account when I split hairs with the delta between my VOA's of engine oil and the UOA's after some use.
The problem I have with this train of logic is twofold:
1. Blackstone has shown a history of recent OA FUBARS. We have no idea how "accurate" this list is.
2. OA's providing single-digit numbers are oft wrought with a lack of repeatability; you are sampling for something so minute, that running the same test on the same lubricant again will yield different results every time.
Essentially: Creating a baseline to factor into your oil analysis using these types of numbers may not necessarily be a good idea.
Now, the FP and visc factors I think would be useful for sure!
