Originally Posted By: Built_Well
I don't seem to lose coolant in the overflow tank gradually. In other words, the loss is not a slow, imperceptible, gradual loss. When the tank is observed cold, the level seems to stay constant for a whole 3 to 5 months at a time. Then, suddenly, after 3 or 5 months, it drops by an inch or two over a very short period of one to three days. The coolant level in the tank then stays at the new lower level for another 3 to 5 months. Then, almost overnight, it again drops another inch or two. The loss over these last 3.75 years has never been gradual, but punctuated by sudden drops.
I got the same problem with my camry though not as bad. I checked the overflow tank early this year and it was low so I filled it back up and checked it a bit more often. Some time during the summer, it suddenly dropped a little bit in a week or so and I saw dried coolant on top of the tank. Obviously it's leaking from the cap, but I know it's been closed properly every time.
Doesn't seem like your typical cooling system problem. Oil looks fine. Car doesn't overheat.
