Greetings all,
I have, as my subject says, a 1999 Lumina with the 3.1L GM V6. It has about 140k on the motor, but it's the second motor in the car. I picked up the car about a year ago with a bum cylinder, consuming incredible amounts of oil. Turns out the previous "mechanic" to do an intake manifold gasket on there put the pushrods in upside down...
As well, the oil was not changed regularly, based on the black sooty mess that was in there. I think these combination of problems led to the dead cylinder (20 psi compression).
Long story short, I obtained a motor with about 1000 more miles than the motor I took out of the car, from my mother who had a Lumina as well and got a new car.
Since I've gotten this car back on the road, I've done about 4-5 oil changes at 4k intervals using full synthetic NAPA 10w30 (I work for NAPA, it's Valvoline Synpower, or at least stupidly close), and trying to reverse some of the abuse of it's previous owner. My mother only drove 10-20 mile stints, if even that on most of it's travels, and tended to forget to tell me when the oil was due for changing.
The synthetic is treating it well, with the oil still a deep amber at 4000 miles, but I think I want to move up to something heavier, possibly in the M1 grouping of oils. I do a lot of sustained high speed driving, and like to do some more, "spirited" jaunts. I drive about 4k a month, so I'm doing oil changes once a month. The motor runs fairly quiet, but as we all know, the 3.1Ls love piston slap, and are fairly noisy on start up.
I was thinking either a M1 0w40 (though from what I've read on here it's quite close to the 5w30 that the car recommends), or a 15w50, which is a little heavier at temperature but still has a good flow point for some of the cold NY mornings.
Any recommendations would be appreciated and heeded!
-ShaunBone
(I'm a trombone player, nothing dirty here 'cept my oil haha)
-ShaunBone
