Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
80 registered members (69GTX, 92saturnsl2, 1JCB, A310, Aero540T, 4WD, 13 invisible), 1,574 guests, and 29 spiders.
Topics290,932
Posts4,852,676
Members66,060
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
BMW M3 calls for 10w-60 - what to use? #1599969
09/14/09 02:43 PM
09/14/09 02:43 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
I know Castrol has a 10w-60 TWS oil; and I know this was covered a month ago (so I will search) whats anyone running in M1 or Amsoil?
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: BMW M3 calls for 10w-60 - what to use? [Re: tomcat27] #1600005
09/14/09 03:15 PM
09/14/09 03:15 PM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
I just did an amsoil lookup on a 2008 M3 with the 4.0L engine, and there is no equivalent amsoil product for that engine.
Try this: http://www.amsoil.com/scripts/runisa.dll?amsoiloaf.587137158:RIGHTPANEL:856409547:M3,BW,N,852.
Mobil 1 I also did a lookup on their site and there is no recommended Mobil 1 product either.
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: BMW M3 calls for 10w-60 - what to use? [Re: mechjames] #1600008
09/14/09 03:17 PM
09/14/09 03:17 PM
mechjames Offline
mechjames  Offline
Here is the official BMW approved list, scroll down for the M engines. http://www.bmwusa.com/Standard/Content/Owner/SyntheticEngineOils.aspx
Re: BMW M3 calls for 10w-60 - what to use? [Re: tomcat27] #1600010
09/14/09 03:20 PM
09/14/09 03:20 PM
SE PA
Trajan Offline
Trajan  Offline
SE PA
If it's under warranty, used what's called for. If not, use it anyway.
They didn't spec 10w-60 for brown organic matter and giggles.
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
Re: BMW M3 calls for 10w-60 - what to use? [Re: Trajan] #1600032
09/14/09 03:42 PM
09/14/09 03:42 PM
USA
JohnBrowning Offline
USA
M1 15W50, RTS 5W40 as well as other brands in this range all work well!
Re: BMW M3 calls for 10w-60 - what to use? [Re: JohnBrowning] #1600076
09/14/09 04:16 PM
09/14/09 04:16 PM
orwellian sheep land?
Max_Wander Offline
Max_Wander  Offline
What a band-aid solution for a poorly designed, yet highly regarded engine. I guess it's easier for the proud german organization to recommend slack wax as a motor oil than it is to admit the problem and fix it for free. That said, the 10w60 is some serious stuff, you'd be chancing it with OTC oil.
Re: BMW M3 calls for 10w-60 - what to use? [Re: JohnBrowning] #1600089
09/14/09 04:26 PM
09/14/09 04:26 PM
PA
d00df00d Online content
d00df00d  Online Content
PA
Here's why I and my friends who drive BMWs that spec the 10w-60 are wary of alternatives:
- BMW's M division worked with Castrol to develop the engines and the oil together.
- BMW takes every opportunity to consolidate fluids across its models. They never use a different fluid for one of their cars unless it's necessary.
- We can be pretty sure this isn't a marketing thing to make the owners feel special, because the M division's turbo engines for the X5 M and X6 M do not specify the 10w-60. They run on the 5w-30 like almost every other BMW.
- Any time a manufacturer specifies something so unusual, and insists on it so adamantly for so long, it's worth listening.
- The Castrol 10w-60 in question may be one of the toughest street oils money can buy, period.
Now, this isn't to say there is definitely no alternative. Mobil insists their 0w-40 will do just fine, and given how cautious they are with what they say, I'm inclined to believe them. There are also a few alternatives in the thread below, although it is probably too soon to tell how those cars will hold up in the long run:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1570914
Bottom line: It's a gamble, and we don't even know enough to say how safe that gamble is. Unless you're particularly adventurous, I'd recommend sticking with BMW's recommended oil.
2011 Mazda RX-8 R3
Mobil Super 5w-20
Re: BMW M3 calls for 10w-60 - what to use? [Re: Max_Wander] #1600098
09/14/09 04:34 PM
09/14/09 04:34 PM
PA
PA
You're thinking of the S54 from the E46 M3, yes?
The failures were a result of manufacturing defects and a couple of design oversights. Those have long since been corrected.
That engine is now totally reliable. Despite being undersquare and producing over 100 hp/L, it will run at 8,000 RPM all day for years without even blinking. A friend of mine has over 100,000 miles on his, including several thousand track miles. The valvetrain looks like new, and so do his acceleration times. Not one drop of oil consumption, either.
(He uses the factory oil, by the way. wink )
2011 Mazda RX-8 R3
Mobil Super 5w-20
Re: BMW M3 calls for 10w-60 - what to use? [Re: d00df00d] #1600106
09/14/09 04:41 PM
09/14/09 04:41 PM
Max_Wander Offline
Max_Wander  Offline
Yeah the S54 was an example of pushing the limits of displacement on the block. A good engine builder would hold the rod length as a very integral part of reliablity. It seems BMW tried to go the Honda route, very short rod (which helps excite movement at the intake port), combined with wild camming. It works, yes, but it's not too reliable. Even Honda has limits, which is why they overbored the H22 and cut the stroke comapred to the H23 (and applies to F22C as well).
Do you think BMW is just playing it safe with the S65 and the special 10w60 ester lube? Because I mean, you're totally right about the 10w60 being some hardcore stuff! Nothing on the shelf of WalMart can compare, really.
Re: BMW M3 calls for 10w-60 - what to use? [Re: Max_Wander] #1600124
09/14/09 05:00 PM
09/14/09 05:00 PM
PA
PA
That's a good question.
In a way, all oil recommendations are "playing it safe" because you always want the largest operating margins possible. But what I think you mean to ask is, is it safe to assume that the engine doesn't actually need something that tough? That is certainly possible.
At the same time, I feel like it defeats the purpose of a BMW to push the limits of performance at the expense of safety/longevity. Plus, even with the 10w-60, the engine already has very little internal friction and highly efficient cooling. I don't think there is a lot to be gained by switching to a lighter oil, whereas there is certainly a lot to risk.
2011 Mazda RX-8 R3
Mobil Super 5w-20
Re: BMW M3 calls for 10w-60 - what to use? [Re: tomcat27] #1600172
09/14/09 05:50 PM
09/14/09 05:50 PM
Airlie Beach Australia
Doug Hillary Offline
Hi,
tomcat27 - A previous Poster said this:
"The failures were a result of manufacturing defects and a couple of design oversights. Those have long since been corrected."
The faults were various and concerned the lubrication system to some degree. The 10W-60 lubricant was a quick "fix it" solution at the time
BMWs typically run with quite hot oil temperatures and I was always amazed at what they were in my Z3 2.8. In the M3 130C was quite common and a "cut off" point!
Mobil recommend M1 0W-40 or their semi-synthetic 10W-40 here in OZ and in New Zealand. Castrol recommend similar viscosities
You can safely use M1 TDT 5W-40 (Delvac 1 5W-40) or its new quivalent in NA
I used this lubricant in my Z3
Regards
Doug
Re: BMW M3 calls for 10w-60 - what to use? [Re: d00df00d] #1600243
09/14/09 07:31 PM
09/14/09 07:31 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
As an engineer, I can say that when a manufacturer try something like this, it is to hide a design defect that has no cost effective work around.
I don't think it is just the viscosity, but the additive package is also hacked to provide such a band-aid solution to the problem.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: BMW M3 calls for 10w-60 - what to use? [Re: PandaBear] #1600281
09/14/09 07:51 PM
09/14/09 07:51 PM
PA
PA
Fine. Let's grant that for the sake of argument. That's not exactly a good reason not to use the thing in question, is it?
2011 Mazda RX-8 R3
Mobil Super 5w-20
Re: BMW M3 calls for 10w-60 - what to use? [Re: PandaBear] #1600284
09/14/09 07:52 PM
09/14/09 07:52 PM
CA
BuickGN Offline
BuickGN  Offline
CA
Sounds like a large assumption. Doug commented on the high oil temps in many BMWs. Maybe an 8,500rpm semi large displacement engine needs the HTHS. Remember, this thing is made to be run all out for hours on end without breaking.
84 Buick GN. [email protected] old times. 602hp 620lbs.
06 Acura TL. Lots of suspension and brake mods.
Re: BMW M3 calls for 10w-60 - what to use? [Re: PandaBear] #1600297
09/14/09 08:04 PM
09/14/09 08:04 PM
Toronto-ish, Canada
Craig in Canada Offline
Toronto-ish, Canada
That comment may have had a lot of truth back when the S54 was first spinning rod bearings. Several years and generations of M engines down the road, I highly doubt the same "design defect" is still present with no workaround and simply being hidden by 10W60.
Page 1 of 5 1 2 5
