Anyone every see this in any stores? If regular MMO keeps the locks in Ranger working this winter (nothing else has) it's going on my shopping list. Haven't seen it at any of the parts store or big box stores around here.
Toyota used to recomend synthetic engine oil for keeping locks clear. I used to take M1 5W30 pour some in a paper dish and dip my key in it then instert it into the lock and twist a bunch of times and repeat. I have never had an issue. I even do my ignition locks before winter comes!
Never seen it at WalMart.. although I've never really looked. May just get a oil can or spray bottle and dispense it that way. I did the same process with MMO. No lock problems in almost two months.
believe me, the best thing you can do for preventing your locks to freeze, is to put the straw on the WD40 and spray a little in. Do it as often as you like all winter.
THIS WORKS ! WD means WATER DISPLACING
