Originally Posted By: sciphi
Bingo, at this point I'm leaning towards this being a problem with the plug wires/plugs. Plan to take this to dealer to see what they say.
Having done the professional fuel system cleaning (and unprofessional seafoaming) remaining possiblities include bad plugs/wire/coils or some kind of insoluble obstruction in the fuel injection pintles, since the cleaning wasn't done through the fuel rail.
Went to the dealer today for state inspection. Quoted me $130 for doing a computer diagnostic inspection + any reflashes if needed. Also told me that my spark plugs were "way overdue" for replacement (should be replaced at 30,000mi). LOL.
The lack of good salesmanship at dealerships is frightening. Why assume that anyone who knows about computer diagnostics and reflashes would fall for a line like that?
With no CEL, there is no immediate urgency. So to make this sale, the best line would have been to say "I can do your state inspection for $30, and since there are no obvious problems, and you want to be careful, I'll give you a break on doing a computer diagnostic run. Make it $100 flat for both."
Oh well, no sale here.
Now this may be a PT cruiser specific thing, but I don't understand the idea of shooting Seafoam through the brake booster line, when you have a big thick vacuum line comming out of the PCV valve. This line attaches right after the intake butterfly valve giving you the most even distribution into the plenum.
The PCV system is designed this way because otherwise oily vapors would be directed causing uneven engine fouling. The brake booster just needs vacuum, so it doesn't matter where it is installed in the manifold.
Deep Creep is going to be aerosolised vs the having actual amounts of liquid sloshing about. That's what would scare me if I was using liquid seafoam and funnel. You pour too much in, and a big slug of seafoam hits all at once.
I'm not sure how much the physics of all this have been studied but I imagine that some of the cleaning action is due to solvation effects, and others due to vapor formation as the seafoam/water saturates the deposits and turns to steam/vapor. Maybe you need the right balance of non-combustable material to be effective.
And some of the cleaning could be due to the high RPM's that happen when you let air get into the intake manifold.
