Hello,
I have an 09 Cobalt SS that has a 2.0L Ecotec engine that is turbocharged and has direct injection. In selecting an oil for this car what properties of the oil are important to consider. I've heard that the turbo can "cook" the oil when the engine is shut off and the oil isn't circulated through the turbo. I'm not sure what impact the direct injection has on the oil either. Does a lot of gas get into the oil on that type of engine. Another feature of the engine is an inject that sprays oil on the bottom of the piston to help cool them.
The car is daily drive with a 16 mile commute each way to work mainly stop and go driving.
What brand, weight and oil change interval would you recommend? Should I listen to the oil monitor or change it in advance of that at a set schedule of x number of miles?
