Originally Posted By: carock
Are there any four passenger SUV's with excellent bad road capabilities that get better than 21 overall mpg? If the Jeep Wrangler (16.5 mpg) is the gold standard for off road capabilities, how does a cross over like the Toyota RAV-4 or the Ford Escape compare?
I consider "bad roads" to be weather related issues and "Off Road" to be off pavement.
If you're talking about snow and ice conditions, any 4wd car or SUV should perform will with the right tires. The cars have less clearance so you may be able to find snow deep enough to be a problem.
If you're talking about off pavement, which the Jeep Wrangler leads me to believe, unless you get the Rubicon there are several other rigs that have comparable capability. A Toyota Tacoma TRD with a rear locker should do really well off road, they're just a little larger to deal with. Another option is the FJ Cuiser. It all depends on what you want to do. I like to off road in my 89 4Runner (17 mpg mixed with 22RE and 35 inch tires) in places that only the Rubicon versions could keep up.
If you're really planning to go off road, stay away from anything that is based on a car chassis. I call them Sport Utility Cars, or SUCs. Example, Toyota 4Runner is a truck chassis while a Highlander is a car chassis, they are almost identical in size. Another thing is to make sure you have a real 4wd system.
Oh, lockers are BAD on ice unless you are planning to go slow. My 4Runner is locked front and rear and is a beast above 30 mph, but I can drive in the ditch if need be.
