Just wondering, if there is the same importance placed on gear oils for cold weather performance.
Engine oil is obvious, the fluid is pumped, and the faster it can get to the head the better.
With gear oil though, they warm up fast, and have huge heavy gears stirring the butter so to say.
The reason Im asking, is from the other post. Ive done enough research, and even contacted torco (who was great) and they said that either syn or conventional would be fine, but could see where the conventional would offer an advantage in SOME situations ie. slow moving offroad situations with heavy gear loading.
I ordered some 80w140 torco conventional. it pours down to -20, which is the same as my current 80w90 castrol
Any thoughts?
Any thoughts?
