1999 Honda ST1100
Water-cooled V4
Shared engine/trans. oil, wet clutch
Comments:
Shell Rotella 5W40 oil the CI-4 version
Bosch automotive oil filter
FP3000 and Redline Lead Substitute in the gas.
I'm not too worried about the Sodium, it is not coolant. I am using Redline Lead Substitute
in the fuel to help protect the valves and it is Sodium-based. I have used it before and it
shows up in the oil tests.
This oil has been in the bike a little longer than normal.
Blackstone Labs Test results:
Oil...............Rotella 15W40 CJ4 ....Max Life 10W40....Delvac 15W40....Rotella 5W40
Filter............1536 Napa Gold....PL14612 Purolator....PL14612...........Bosch 3423
Total Miles....97,045................110,996................119,028................127,052
Miles on oil....8,017.................8,016...................8,062...................8,024
Time on Oil.....5 Mo...................2 1/2 Mo............3 1/2 Mo................6 Mo
Make up oil......0.......................0..........................0.......................0
Aluminum.........9...................8...........................10........................7
Chromium.........0....................1.........................1.........................1
Iron................23...................14....................14.....................16
Copper............3....................3.....................3.......................5
Lead...............3....................3......................3.......................4
Tin.................0....................1......................0......................0
Moly...............249..................82....................51....................9
Nickel.............0....................0.....................0.....................0
Manganese......0.....................0......................0......................0
Silver..............0....................0.....................0.....................0
Titanium..........0....................0......................0......................0
Potassium........2....................2.......................2.......................3
Boron.............13...................37.....................27......................7
Silicon.............12...................12....................11....................11
Sodium.............10....................332....................343....................262
Calcium............2588....................1719.................1169.................2722
Magnesium.........9.......................827...................735....................92
Phosphorus......742........................963...................806...................1051
Zinc.................863........................1300...................1018...................1276
Barium.............0..........................0........................0........................1
Flashpoint F......385........................410.......................385.......................390
Fuel................ Antifreeze........0......................... .66........................ ??........................ ??
Water.............0..........................0...........................0...........................0
Insoluables......0.2........................0.3........................0.3........................0.2
SUS Visc@210f..61.5........................68.4......................66.0......................66.1
cST Visc@100c..10.64.......................12.54.......................11.89.......................11.91
TBN.................3.1.........................3.1........................4.2........................6.1
Water-cooled V4
Comments:
