Originally Posted By: Pete591
Thanks...what were the steps to get it installed..looks like a very tight space..
yea a little it was had to thread the 1/2 nipple into the T then spin the T with nipple into the port tighten down then thread the temp sensor in followed by the pressure hose fittings last,couldn't get it spin around with all the other fittings on to wide.
then proceeded with the wiring and routing the hose. used a 1-1/2" and a 2" hole saw for the cut outs in the dash.
Originally Posted By: Jim 5
Nice work. I'd swap out that plastic tubing for copper though. I've seen those plastic ones break or slip out of the fitting a few times now. Nothing like an oil squirt gun behind your dash!
i thought about that too,along with the heat issue being by the engine, have to hunt for a copper tubing kit maybe.
I've never had too much trouble finding it by the foot at old school auto parts places. Most places sell the brass ferrules too.
thanks ill check it out...
