steve20 said:after the STP is diluted with 5 qts of engine oil, howe much of an increase in PPM is there--? probably not much to make any difference
Steve20. With that amount of zinc it will raise the zinc levels
around 90 to 100 ppm. So if the zinc level of your typical
SM oil is around 850ppm, then adding one bottle to 4.5 L/qts
of oil should bring the level up to about 940 ppm of zinc.
