BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
88 registered members (2015_PSD, 4WD, aquariuscsm, 14Accent, Anduril, 9 invisible), 2,030 guests, and 55 spiders.
Topics306,135
Posts5,288,111
Members71,604
How does this block heater work? #1572012 08/19/09 06:14 PM
R
rcy Offline OP
R
http://www.metrotpn.com/ProductDetails.aspx?CollectionID=25&ProductID=191&SortIndex=14
It's for certain Toyota/Lexus models. The instructions indicate that it does not go in the coolant, but rather into a hole in the block.
Does this make sense? Any pros/cons to this style of heater over one that actually sits in the coolant?
Re: How does this block heater work? [Re: rcy] #1572032 08/19/09 06:38 PM
U
Ursae_Majoris Offline
U
Had one in my 05 Tacoma. V6 had a "cavity" in the engine block that was surrounded by coolant on the other side. Heater heated the walls of the cavity, which, in turn, heated the fluid. I loved it. Very easy to install (under 30 min), do not have to mess with freeze plugs or add coolant. Heater set comes with a packet of dielectric grease to coat the heater cartridge. It prevents dirt from building up in the cavity and helps with heat transfer. Worked just as well a freeze-plug heater in my Isuzu.
The little clip on the side snaps onto the block and holds the cartridge in place. It took longer to route the wire than installing the cartridge. The wire disconnects from the cartridge itself, so install is easier, wire is a regular 3-prong heater wire, so it is very easy to replace, if you need to.
Re: How does this block heater work? [Re: rcy] #1572099 08/19/09 07:49 PM
Saturn_Fan Offline
I installed that same one on my 08 Corolla last Fall. Had to order it from Canada though.
It was super easy to install. Took me around 30 minutes. Came with the thermal grease and snapped right into a recess in the engine block.
Works like a champ and helps greatly in -20F.
I think I paid 49 bucks for it online through a Toy dealer.
08 Toyota Corolla CE, 20K miles, 1ZZ-FE 1.8L, Castrol Edge 5w-30 & M1 EP filter
00 Saturn SL, 108K miles, 1.9L, Pennz Plat 5w-30 & M1 EP filter
Re: How does this block heater work? [Re: rcy] #1572126 08/19/09 08:15 PM
P
Paul56 Offline
P
Yeah, that is called a block heater.
One of the freeze plugs is removed and this installed in its place... and yes this actually sits in the coolant.
Re: How does this block heater work? [Re: Paul56] #1572133 08/19/09 08:22 PM
Saturn_Fan Offline
It doesn't touch coolant and there is no plug to remove to install this. I just did this not too long ago on a brand new Toyota.
There is a void in the casting of the engine block and it is smooth like a long cylinder. This simply gets greased up with thermal grease and slid into this until it bottoms out and snaps into place. It transfers heat to the aluminum of the engine block.
Re: How does this block heater work? [Re: Paul56] #1572139 08/19/09 08:27 PM
R
rcy Offline OP
R
Not to be rude, but did you actually read my post, or look at the link provided?
Specifically this part from the link - "Does not require removal of any freeze plugs, engine block is ready-made for this accessory."
This particular block heater does not sit in the coolant.
Re: How does this block heater work? [Re: rcy] #1572163 08/19/09 08:45 PM
Saturn_Fan Offline
Exactly! It merely heats up the air in the void it sits in and the heat energy is absorbed into the aluminum and spreads around the entire block overnight.
And it works like a champ in the winter in my Corolla!
Re: How does this block heater work? [Re: Saturn_Fan] #1572197 08/19/09 09:13 PM
R
rcy Offline OP
R
Oh well, as it turns out, this is not the block heater for my vehicle. I was so hoping that I wouldn't have to drain my coolant. Apparently, the correct part for my vehicle, is the traditional in coolant block heater.
Thanks for the replies.
Re: How does this block heater work? [Re: rcy] #1572205 08/19/09 09:20 PM
P
Paul56 Offline
P
Now now... no need to get fiesty since it was me who was the goofball here. :-)
I would expect a block heater that actually sits in the coolant to be more effective... particularly with the kind of winter temperatures I'm dealing with.
Re: How does this block heater work? [Re: Paul56] #1572238 08/19/09 09:42 PM
U
U
Worked great at 30F below up her in AK.
Re: How does this block heater work? [Re: Paul56] #1572275 08/19/09 10:13 PM
R
rcy Offline OP
R
[/quote]
Umm..yeah. Sorry, I was kind of short with my reply.
I would tend to agree with you regarding an immersion type heater to be more effective, but a lot of the responses indicate that the conductive type heater works quite well.
Re: How does this block heater work? [Re: rcy] #1572288 08/19/09 10:32 PM
Saturn_Fan Offline
[/quote]
I have the actual product listed and put it in a brand new car. My car saw temps with it installed of -10F frequently with some -20F and even some -25F temps thrown in.
I touched the block in -25F and it was luke-warm, thus, the heater did its job.
These heaters are commnonly put on Toyotas in Canada. In fact, you will seldom find them in the US or any dealers willing to obtain you one. I had to search high and low to find one.
My other car, a 2000 Saturn SL1 4 cylinder has a block heater installed on it and it is factory part. It also is NOT immersed in cooolant and just sits on a clip next to the engine block. It works well in the same temps as above.
Just because the heater is not installed directly into an engine plug doesn't mean it is not effective.
Re: How does this block heater work? [Re: Paul56] #1572396 08/20/09 12:17 AM
G
Gary Allan Offline
G
You blew it. LOL You could have merely said that the two other gentlemen, although totally correct in what they were describing, were mistaken for the type of heater that the OP needed. LOL
Re: How does this block heater work? [Re: rcy] #2897623 02/06/13 05:15 PM
P
ppyzyna Offline
P
Is it thermostatically controlled?
Re: How does this block heater work? [Re: rcy] #5260388 11/07/19 12:45 AM
M
Mendel_Leisk Offline
M
I had the style of block heater described in this thread (non-immersed, heater element in a bore, adjacent to coolant passage) installed when we bought our 2010 Prius, in November 2010. It recently shorted out, and I removed it. There's supposedly a special thermal transfer grease applied to the heater element before it's inserted, but when I extracted mine I found the element dry, and very clean.
My first thought was that the dealership-installed block heater never had the grease applied. Or maybe it was, but had baked off over the years?
I purchased a replacement, and installed it myself this time. The grease pack supplied with the block heater is labelled "NSCG silicone grease G-624". I'm thinking to check it in about 6 months, see how it's holding up, and would like to have a tube of the proper grease on hand, just in case it needs replenishment.
To find an appropriate grease, so far I've:
1. Asked dealership parts department (no luck),
2. Posted questions on Amazon (one in particular that seems promising: "SuperLube 91003 3 oz. Tube Silicone Hi-Dielectric & Vacuum Grease"). Someone mentioned that it had been used by GM for a high temp application.
3. Talked to manufacturer of a similar third party block heater (Kats): they recommend to use "SCG silicone grease G-624", but don't supply it with their products, and couldn't give me a source.
4. Attempted to contact Novagard (regarding their "Versilube G-624"); no response so far.
My sense, it's a silicone grease, maybe with additives to help conduct heat better, and it (hopefully...) stays stable in the high temps of a block heater application.
I'd really appreciate ideas, recommendations, a grease that'd work in this case. Or comments on the products mentioned above.
