(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
99 registered members (1.8Tango, 2003f7, 97f150, 2015_PSD, 10 invisible), 1,642 guests, and 32 spiders.
Topics296,613
Posts4,955,834
Members66,950
Most Online2,577
Yesterday at 03:43 PM
Page 1 of 17 1 2 17
PUREONE BETA RATES! #1566061
08/14/09 03:01 PM
08/14/09 03:01 PM
Puget Sound, WA
SHAMUS Offline OP
SHAMUS  Offline OP
Puget Sound, WA
In response to my request, here is what Purolator states its beta rate is on the PureONE:
Hi Katrina,
Here are the Beta Ratios for the PureOne that was requested.
Below I put the standard beta ratio chart for comparison.
Micron 5 = B4.8
Micron 10 = B50
Micron 15 = B1000
Micron 20 = B1000
Standard
You would typically see
Beta Ratio Efficiency
2....................50%
10....................90%
20....................95%
75....................98.7%
100....................99%
200....................99.5%
1000....................99.9%
Using the standard ratio numbers here is our PureONE.
(> = greater than; m = microns)
B2 = below 5 m
B10 = 6.69 m
B20 = >8 m
B75 = >11 m
B100 = 11.42 m
B200 = >13 m
B1000 = >15 m
I hope this isn't too confusing.
Once again, I don't get a wall of secrecy from Purolator when I need answers. Their beta rates are yet another reason why I only use the PureONE! Does anyone have this data on the Amsoil/Mobile 1/Royal Purple filters?
A HIGHLY TRAINED, PROFESSIONAL IDIOT
Re: PUREONE BETA RATES! [Re: SHAMUS] #1566109
08/14/09 04:06 PM
08/14/09 04:06 PM
California
BimmerMan Offline
BimmerMan  Offline
California
<5 micron....................50%
6.69 micron....................90%
>8 micron....................95%
>11 micron....................98.7%
11.42 micron....................99%
>13 micron....................99.5%
>15 micron....................99.9%
Is that right?
2000 BMW 528i
1992 BMW 325is
Re: PUREONE BETA RATES! [Re: BimmerMan] #1566138
08/14/09 04:24 PM
08/14/09 04:24 PM
Puget Sound, WA
SHAMUS Offline OP
SHAMUS  Offline OP
Puget Sound, WA
Guys like SuperBusa and Gary Allen are the sharpest at this. I don't think you have it exactly right as Purolator says 99.2% efficient at 15um, 92.8% at 10um, and 51.3% at 5um. Honestly, I do not know how to use the math.
Re: PUREONE BETA RATES! [Re: SHAMUS] #1566191
08/14/09 05:01 PM
08/14/09 05:01 PM
Everett, Washington
oilboy123 Offline
oilboy123  Offline
Everett, Washington
15 microns 98.7% for the Amsoil EA
ISO 4548-12 Is what they are using. I don't know what the other specs are Maybe Gary or Pablo.........? The Pure One is what I use when I don't have the right EAO filter.
Loyalty to country ALWAYS. Loyalty to government, when it deserves it.
&#8213; Mark Twain
Re: PUREONE BETA RATES! [Re: SHAMUS] #1566195
08/14/09 05:03 PM
08/14/09 05:03 PM
New Jersey
crazyoildude Offline
New Jersey
I like the pure one also but i was always a little concerned about flow rate
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: PUREONE BETA RATES! [Re: SHAMUS] #1566213
08/14/09 05:21 PM
08/14/09 05:21 PM
Pottstown, PA
Gary Allan Offline
Gary Allan  Offline
Pottstown, PA
Micron 5 = B4.8
Micron 10 = B50
Micron 15 = B1000
Micron 20 = B1000
5um and greater = 79.2
10um and greater= 98%
15um and greater= 99.9
20um and greater= 99.9
These are exceptional numbers. Not matched by high end incredibly expensive filters from Donaldson that Purolator doesn't even make.
20 Series Particulate removal spin-on filters. 3.69" diameter. Two lengths available (5.27" and 8.64"). Three media grades (10 micron paper, 25 micron paper and 7 micron fiberglass). 100 psi pressure rating. Buna N gasket, 1" - 12 UNF threads. For detailed information, request bulletin #20/21-5/01-2K or download PDF brochure.
http://www.purolator-facet.com/pdfs/spin2021.pdf
You can't buy a FL1A sized hydraulic filter from them at that micron rating, let alone a static spec for a much dirtier automotive environment.
http://www.purolator-facet.com/hydrau4.htm
This is too fantastic to be quite right.
Re: PUREONE BETA RATES! [Re: Gary Allan] #1566240
08/14/09 05:53 PM
08/14/09 05:53 PM
WA
SuperBusa Offline
SuperBusa  Offline
WA
SHAMUS - from the other thread, you showed the info below (in your quote), which was apparently also from Purolator.
 Originally Posted By: SHAMUS
Filtering Efficiency: BELOW AVERAGE?
PureONE:
25u - 100%
20u - 99.9%
15u - 99.2%
10u - 92.8%
5u - 51.3%
In your original post in this thread, I'm a little confused on what part of the info is directly from Purolator, since it starts off "Hi Katrina" ... who is the gal at Purolator that provides this stuff. What info is from Katrina?
Here's the info you showed in the quote above, but converted to "Beta Ratio".
u -- Beta Ratio -- % Efficient
25 -- infinite -- 100.0
15 -- 1000 -- 99.9
10 -- 125 -- 99.2
5 -- 2.052 -- 51.3
Beta 1000
Condition 0
Re: PUREONE BETA RATES! [Re: SuperBusa] #1566287
08/14/09 06:16 PM
08/14/09 06:16 PM
WA
SuperBusa Offline
SuperBusa  Offline
WA
Correction to what I posed above (time limit expired for editing of above post).
25 -- "infinite" -- 100.0
20 -- 1000 -- 99.9
15 -- 125 -- 99.2
10 -- 13.8 -- 92.8
5 -- 2.052 -- 51.3
This conversion was done by using the filter efficiency as a function of Beta Ratio formula of:
(B-1)/B x 100 = % Efficiency
B = Beta Ratio in formula above.
The above formula is from the Filter Counsel Tech Bulletin, and used in industry to describe % efficiency.
Beta 1000
Condition 0
Re: PUREONE BETA RATES! [Re: crazyoildude] #1566313
08/14/09 06:36 PM
08/14/09 06:36 PM
WA
SuperBusa Offline
SuperBusa  Offline
WA
From what limited data I've seen, the PureONE flows just as good or better than any other high efficiency filter.
This is relative data, and you can see that the PureONE is up there with the others in terms of less flwo restriction than some others listed.
Beta 1000
Condition 0
Re: PUREONE BETA RATES! [Re: SuperBusa] #1566404
08/14/09 07:50 PM
08/14/09 07:50 PM
TN
Lurch Offline
Lurch  Offline
TN
Glad to hear this. I saw in an article today that the PureOne and Bosch both have the most filter area. :)
03 Nissan Sentra XE | 68k | Rotella T 5w40 | PureONE
03 Kawasaki ZR 7S | 14k | Delvac 15w40 | Fram CH6012
Re: PUREONE BETA RATES! [Re: SuperBusa] #1569465
08/17/09 01:30 PM
08/17/09 01:30 PM
Puget Sound, WA
SHAMUS Offline OP
SHAMUS  Offline OP
Puget Sound, WA
This is from one of the Purolator engineers responding to Katrina. She did not have the data I was asking for so she sent my email to their tech dept. Yes, both the effieceny ratings (microns) and the beta ratios are from Purolator, just sent at different times. The engr tech's name is Brian Crawford at Purolator.
Re: PUREONE BETA RATES! [Re: Gary Allan] #1569481
08/17/09 01:41 PM
08/17/09 01:41 PM
Puget Sound, WA
SHAMUS Offline OP
SHAMUS  Offline OP
Puget Sound, WA
"This is too fantastic to be quite right." - Gary Allen.
Well, email them for yourself. Again, the engr's name is Brian Crawford. I suppose it is possible the tech has a typo in his reply to Katrina (?).
Re: PUREONE BETA RATES! [Re: SHAMUS] #1569502
08/17/09 01:56 PM
08/17/09 01:56 PM
Pottstown, PA
Gary Allan Offline
Gary Allan  Offline
Pottstown, PA
I may...but just subject it to common sense practical review.
Why ..or even HOW COULD Purolator market a variable size filter in a VERY DIRTY automotive environment with spec's that can't even be matched by their own industrial (clean) hydraulic offerings?
The two environments aren't even in the same league for loading potential.
If this is "true" without some oddball qualification ..then you've got a magic filter. Donaldson, Wix, Champ would love to be able to trump their own exclusive filters by just rebranding Purolators and selling them at the premium that they already get.
Forget SYNTEQ ..forget Stratapore ..there's a new sheriff in town ..and it's a $5.99-$6.99 Purolator that can be the size of a teacup (PH3614) or an FLIA filter and it will last over any OEM service length regardless of application.
Purolator PureOne's are a great filter ..I'd say for those not requiring the open end bypass valve ..just about the best bang for the buck to be had.
..but this is something that is just counter to common sense in the entire filter industry.
Re: PUREONE BETA RATES! [Re: Gary Allan] #1569506
08/17/09 01:59 PM
08/17/09 01:59 PM
Puget Sound, WA
SHAMUS Offline OP
SHAMUS  Offline OP
Puget Sound, WA
Re: PUREONE BETA RATES! [Re: SHAMUS] #1569525
08/17/09 02:17 PM
08/17/09 02:17 PM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
I'm not a real stickler for efficiency, flow rate, or even by-pass pressure differential. But I do need a good ADBV in an oil filter for one of my vehicles, and the Pureone ADBV is tough to beat. All this other stuff is just icing on the cake.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
Page 1 of 17 1 2 17
