Originally Posted By: 09rexwagon
I have the same one as the OP but purchased at AZ many years ago...the drain lid doesn't leak like a lot of people say about the Blitz one. I do have two gripes: BuickGN nailed it with the oil spray from the center hole because let's face it, you lose the center plug after the first use. . . .
Ah, but wait. The new version (you'll understand why I own it in a moment) has a little "T-thingie" on the bottom of that center plug. It allows you to unscrew it, but not actually remove it all the way from the drain hole. That's a good thing. A few changes back, I had the drain bolt slip from my hand, and fall so as to perfectly plug the drain hole. With very hot oil rapidly submerging it, I had no hope of getting to it. As I've posted before, you can put the rest of this sorry story together yourself. . .
